Question about Kenwood KDC-2011S CD Player
Kenwood kdc 3011 rests its self every time i turn the car off
It resets its self every time i turn the car off . It kicks out the cd and the radio station reset also. When i hooked up the wires red to red yellow to yellow i got nothing no power so i connected the yellow together with red and i got power but it resets its self every time
  • Anonymous Mar 13, 2014
    Used truck new to me. Radio/blue tooth worked fine for 4 months. One engine start and I had nothing to the unit. No sign of power at all. Hit the reset and the unit came alive, however now it will not stay connected to any station or the bluetooth. The connect/disconnect is totaly random in duration, from a few seconds to 20+ miles. I don't use the Pandora or the USB port.
  • Anonymous Mar 28, 2014
    I can't catch no stations on the radio everything is put together right I have a kenwood kdc-200u help please
  • 78 Answers
This means that the power lead you connected the red and yellow to is a switched live and each time you turn off the ignition the power goes off and therefore resets. to fix this problem you need to connect the yellow to a permanent 12v supply that stays live when you turn off the ignition.
Posted on May 28, 2008
Pioneer radio wont retain station memory
clock probably doesn't stay either.....sounds likke the wiring may be incorrect...there are 2 battery + leads on these radios...One is yellow...which should be hooked up to a hot lead that is hot all the time even with the key off( you could just run a wire to the positive side of the battery)..thios lead is the memory lead that keeps stations, settings, and the clock....then there is the red lead that is supposed to be hooked up to a switched positive lead...such as the accessory lead fron the ignition switch....it's a good bet that the red and yellow leads are hooked together and that they are hooked to a switched ignition lead right now...all you have to do is disconnect the yellow lead from where is hooked now and hook it to a hot all the time then your memory, and stations should be retained
May 10, 2011 | Pioneer Deh-1200mp Car CD/ MP3 Player
JVC KD-R312 CD player keeps resetting itself whenever the ignition is turned off. The radio stations are ok, but mybass, treble, loudness etc always resets itself. Is annoying because i ahve to go through...
You are losing the permenant 12VDC on the Radio. This is the thick yellow wire from the radio loom, it has to be connected all the time to 12VDC.
Cheers
Oct 27, 2010 | JVC Car Audio & Video
Every time i turn my truck off the equilizer resets
If you radio doesnt save the stations either when you turn off the truck then it could be your wiring.. For example; Normally you have two power wires.. A red one(Accessory).. and a yellow one(Battery). The yellow one is like the memory.. and the red one powers the stereo when you turn the key. Try switching yours over.. See if that helps. Easily confused and you wouldnt really notice the difference.
Jan 14, 2010 | JVC KD-R200 Car CD/ MP3 Player
I just put in a radio in my 88' truck and i have to reprogram my stations every time i start my truck,why is it not holding memory?
Your red memory wire is not hooked up or you switched the red and yellow ignition wire around and your radio stays powered up when you turn off the ignition.
Oct 17, 2009 | Dual XDMR-7700 CD Player
My car radio has to be reset every time the car turns off
i don't know what kind of car that you have but on that radio there should be two power wires one is red and the other is yellow,the red wire connects to the wire in the car that will only have power when the key is turned to the on position,the yellow wire connects to the wire in the car that always has power with the key off.........
Jul 01, 2009 | Panasonic CQ-C1303U CD Player
How do you store radio station in memory?
you have the constant power wire and switched wire backwards.
Switch the red and yellow wires around.
Thanks for using FixYa - A FixYa rating is appreciated!!
Feb 16, 2009 | JVC KD-HDR1 CD Player
No memory
Did you in stall by your self?? Sounds like you may have taking the memory yellow wire and with the red wire Primary switched and hooked them to the switch (Acc) on the harnes . Try looking at the harnes and see if the harness from the radio to the fact harnes hass a yello or red wires . Un hook them and try them in reverse
Dec 03, 2008 | Kenwood KDC-MP228 CD Player
Stored radio stations and time erase when car is turned off
The radio was installed incorrectlly. Make sure the red wire from the radio is connected to a switched 12 volt source(has voltage when car is on, none when it's off) The yellow wire to a constant 12 volt(hot at all times) this wire mantains the radio memory and must always have power.
Nov 21, 2008 | JVC KD-G220 CD Player
DehP6700 mp restet everytime keys is turned on.
first red is ignition or acc (turns off and on with the key) yellow is constant power (always hot keeps memory) orange is illumination (lights up radio) if vehicle doesnt have a seperate illumination wire connect it to the ignition wire. now process of elimination your ground is correct because it worked with all wires to acc your acc works because u had all them connected to it and it worked your problem is in your yellow or constant/memory i suggest u test it again take piece of wire any old thing long enough will do and run the wire directly from the battery under the hood and just run it outside the car through the window and connect it directly to the yellow wire make sure u have a good connection at the battery on the positive side if u have test light or volt meter test the wire before connecting it to the radio if it works then u know there is a problem with the wire from the vehicle (fuse wrong wire bad wire ) if it doesnt work make sure ground is connected tight and that paint is cleaned of the surface where ground connects and that the yellow wire to the radio is tight in the back of the radio.
Nov 13, 2008 | Car Audio & Video
Kenwood KDC-2011S CD Player Logo
792 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
