Question about DeLonghi Ovens
I have a delongi edf 495 st. the main ove light comes on and the fan goes round but there is no heat. im sure it's the heating element gone but how do i replace it
SOURCE: zanussi zbf 760 (9 yrs old now)
make sure the thermostat probe is fully into the oven
Posted on Nov 19, 2007
  • 249 Answers
SOURCE: Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Posted on Dec 18, 2007
barkencoa
  • 3463 Answers
SOURCE: oven not working
You need to detrmine if you are getting a supply to the oven element, if you are , then the new element is faulty, if no supply, then you are going to have to work back from source.
Please rate my solution.
Thanks.
Posted on Jul 21, 2009
  • 119 Answers
SOURCE: kenwood ck405 - main fan assisted oven not heating up
If you are crafty undo the screws on the element and pull put slowly you will see the wires todisconnect
Posted on Feb 17, 2010
barkencoa
  • 3463 Answers
SOURCE: the main oven of my DY46 Hotpoint is not heating up
It will be the element that has gone, and it is easy to replace.
Remove the cover at rear of oven compartment, and you will see the fan element, just undo fixing screw,and replace element.
Posted on Feb 22, 2010
Ywhy does the heat not come on when the fan is switched on,every thing else is working?
Sounds like your round element has gone oc (open circuit)
Isolate the cooker at its mains switch
open oven door
unscrew back panel (normally 4 screws & some times the light glass may need unscrewing)
take off panel, you will see the fan surrounded by a round element,
if its out of shape or in bits, then it needs replacing
you can also take off element detach the wires and test for continuity with a meter if you know what you are doing. Only do this if you have a degree of electrical knowledge!
Jul 16, 2014 | Baumatic Ovens
Switched bottom oven on, then noticed it had tripped fuse for cooker in main fuse box. Swithed it back on and it wouldn't heat up. The fan and light were ok! Top ove? grill works ok still.
sounds like you have a heating element burned out. Look real close at the heating elements and you may see a hole burned in the metal tube. This is a sure sign of a bad element. Some elements are easy to unplug. Others a real pain. Always unplug and or turnoff breaker prior to unscrewing anything. If you fine the bad element just unplug and other element may work OK. Best to get your model number and search net for new element.
May 30, 2011 | Ovens
My Delongi dsf905 oven stopped working
FIRST CHECK THE FUSE IN YOUR PLUG IF OK THEN IT MIGHT BE THE TERMOSTAT IS FAULTY CHECK THE ELEMENT IS NOT BURNT OUT IF SO REMOVE AND BRING TO A ELECTRIC AND PLUMMERS SUPPLY STORE FOR REPLACEMENT.
Nov 29, 2009 | Ovens
SMEG SA410X-S heat not coming on for fan forced cooking. The fan and light work, and the heat works fine for grilling.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
Mar 18, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Fan but no heat
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Jan 06, 2009 | Zanussi Ovens
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Oven not heating up
circular element round the fan has blown. take back panel off inside oven and you will see element. to replace, take rear outside panel off and usually element is held in by 2 7mm nuts on posts sticking out of the element base plate. easy job.
disconnect of course
Jul 11, 2008 | Zanussi ZBF260 Electric Single Oven
Zanussi zbf 760 (9 yrs old now)
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
Ovens Logo
114 people viewed this question
Top DeLonghi Ovens Experts
ashburton
Naftali Haskell
Level 1 Expert
Jason Harris
Jason Harris
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
