Question about Intel Motherboard
Window currupt Hello dear Mellom, Thanks for prompt solution and reaching towards diagonisis of problem and suggetion for corrective action. however i have some more specific doubt which i expect response from you (1) The problem i mentioned in my earlier mail to you was a problem of window XP or it is a promlem in mother board chip set programmes or problem in processor (2) If it is problem in window XP or hard disc why did installation CD of window XP did not asked to reformate the hard disc S C Rawal
  • Suresh Rawal May 28, 2008
    Dear Mr. Mellomania,
    Thanks for a prompt reply and nice interactions.
    As recommended by you I have reformated the C drive of hard disc and started loading Window Xp professional service pack-2. After copying all files when window installation was in progress following message appeared and Comp shut down :
    QUOTE :
    "A problem has been detected & window has been shutdown to prevent damage to your computer.
    IRQL_NOT_LESS_OR_EQUAL
    If this is the first time you have seen this stop error screen, restart your computer, if this screen appears again follow these steps
    Check to make sure any new hardware or software is properly installed. If this is a new installation ask your hardware or software wanufacturer for any windows update you might need.
    If the problem continue disable or remove any new install hardware or software disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable component restart your computer, press F-8 to select advanced startup option and then select safe mode.
    Technical information
    *** stop: 0X0000000A (0X408CE160, 0X00000002, 0X00000000, 0X80818652)"
    UNQUOTE
    Following are the difference in the message on monitor on 26th and 27th May 2008
    On 26th May before formate :
    PAGE_FAULT_IN_NON PAGED_AREA
    and after reformate on 27th May 2008 the message displayed was :
    Kindly give me further advise
    S C Rawal
  • Suresh Rawal May 30, 2008
    Hello dear mellomania,
    Thank you very much for solution and gave me encouragement to formate hard disk and reload the programme. Problem is solved by following:
    (1) Hard disk Patition D was formated because Wndow loading was not successful in Partition C
    (2) Another CD of window was used for insatallation and system is ok now.
    Thanks once again for solution, help and prompt reply to my queris
    S C Rawal
Hello Dear mellom,
Thanks for providing me solution to my PC problem in last week. My PC is working fine so for with window loaded in E drive of hard disk
Problem with C Drive :
(1) I could see some files with folder maned as Window. This was deleted and tried to formate with NTFS as well as FAT32 but message appears as follows " Window could not complete formate.
(2) Now no more files are seen in drive C however it still shows 284 MP occupied space by some files
(3) While booting the PC it shows window XP professional files at 2 places (It does not Indicated Which drive Each XP is ?). It ask to select one of them however booting start on default selected file after about 20 secs and Window Xp get configured and PC start working normal.
(4) I have tried disc check up and clean up of files from C drive > right click >properties >clean disc disc.
Can u guide me to restore C drive of hard disc from here now.
The 160 GB hard disc is mgfd. by Western Digital (WDC) and is under 5 years warranty. How is performance of this hard disc and shall i get this replaced under warranty. This hard disc was purchased on 24th May 2008 (i.e. 1 week before.)
Posted on Jun 01, 2008
  • 121 Answers
1- the problem is a software problem your board and processor are ok.
2- the message you saw indicates curruption in the windows files its strongly recomended that you install a new copy of windows even if the erors could be recovered..
reformating your hard disk is necessary to reinstall a new coppy of windows.
Posted on May 27, 2008
I am setting up a Vision 1 action camera DragonTouch 1 for my grandson. How do I format the SD card that I purchased for tllhis?
Most SD card will fit in your laptop or tablet with an adaptor sleeve. Most laptops today automatically format new memory cards or prompt you to do so. Look on the side of your laptop or tablet for a hole about an inch by 1/8 of an inch slot. Insert the sleeve and follow the instructions. You can go old school and use the command prompt window and drive letter using the command help from the C:>
type help from the C prompt to see the proper commands
example
C:>format D:
or
C:>format E:
etc..
***make sure you have the correct letter or you will clear all the data from whatever letter you use.
Jan 10, 2018 | Action Cameras
Soap dispenser not work
Hello Sean Radler - Confirm that water action is reaching the dispenser; water sprayed from the lower wash arm is directed at the dispenser, reposition any dishes that may be obstructing the water from reaching the detergent cup. Make sure items in the dishwasher do not prevent the detergent dispenser from opening (like tall dishes or cookie sheets). If these items do not correct the issue, there may be a problem with the detergent cup opening. Contact a professional to move forward accurately.
Jan 03, 2013 | Frigidaire 18 in. FDR252RB Built-in...
My action replay ds leaves the start screen but then just goes white even before it reaches the main menu.i tried blowing on it it and it still does the same thing
Hello dijanilaplac,
There can be many problems with your Action Replay DS. Try taking the Action Replay out of your Nintendo DS Lite Console, and look at the part those goes into the DS. Make sure nothing is bent, or missing. If something is, it might mean you may have to have it repaired, or replaced. Also keep in mind that sometimes Action Replays can be sensetive, so don't move it around while playing, or it may cause your DS to freeze up.
If you just bought this Action Replay recently, it should have been supplied with a CD to insert into your computer. You should install Action Replay onto your computer. When you have been brought to the main Action Replay Code Manager, find your USB and Action Replay plug in. Plug the small end into the top of the Action Replay cartridge, and the USB into the computer. Now a New Hardware wizard should have popped up on your computer.
When prompt, select, "Install from specific location.", then click next. Then select Search from CD-ROM. Sometimes it may sound different, just select the one that says something about searching from a CD-ROM. After this has completed, reset your Action Replay.
If the problem persists, feel free to contact me, for questions, or replies.
Nate,
Aug 28, 2011 | Nintendo DS Lite Console
My notebook will not boot up. I hit the on/off button and it lights up then turns off. What should I do? Or is this notebook dead. Any help would be greatly appreciated. Thanks Joyce
Hello
Put your Windows installation disc into the DVD drive of your Toshiba laptop and then boot the laptop.
Press any key on your keyboard when you are prompted. Select your language and your time when you are prompted. Select your currency and the keyboard you are using when you are prompted. Click "Next" on the screen.
Click on "Repair your computer" in the next window. Select your Windows operating system from the menu and then click on the "Next" button.
Click "Command Prompt" in the next window and then type "bootrec.exe" into the prompt. Press the "Enter" button and then type "/FixBoot" into the next window.
Wait for the computer to fix your boot files and then restart the computer automatically.
Apr 22, 2011 | Toshiba Computers & Internet
My ASUS A3 AC has no sound, and I am having problems with the window media reproducer.
Might be the sound driver is currupted to check please try following:
Check with any external speakers or headphone,if there is no sound please reinstall teh sound drivers.
Thanks
Nov 30, 2009 | ASUS Computers & Internet
Boot mgr Is missing on a tobisha laptop
Method 1:
Use the following procedure to repair the file system on the hard drive:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter.
  4. Select a keyboard layout that matches your country/region and click Next.
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field and then click OK.
  7. A System Recovery Options window opens.
  8. Click Startup Repair.
A Startup Repair window opens and automatically scans for startup problems.
  1. Perform the actions suggested by Startup Repair: system restore, correct damaged or missing files, or other action.
  2. After Startup Repair has been used, try to open Windows.
    • If Windows Vista opens, you are done.
    • If Windows Vista does not open, perform the first portion of this section again to open the Startup Recovery Options window and continue.
  3. From the Starup Recovery Options window, click Command Prompt.
  1. Enter the following at the command prompt:
bootrec /fixboot
bootrec /fixmbr
  1. After the bootrec tool has been used, close all open Windows to restart the computer and open Windows.
    • If Windows Vista does not open, continue using these steps.
  2. Perform a full system recovery using recovery discs. For more information refer to the HP support document Performing an HP System Recovery in Windows Vista .
If the recovery cannot be completed from recovery discs, replace the hard drive.
Sep 13, 2009 | IBM ThinkPad T43 Notebook
I need drivers my laptop currupted i can't open it anymore
Without the cd there isn't much you can do. Unless you can find one you'll have to hope your laptop has a system restore option but you would also risk losing all your data doing so.
I doubt you can get to safe mode, but give try safe mode with command prompt and type chkdsk in the cmd window.
Mar 23, 2009 | Toshiba Satellite 1955-S801 Notebook
Hard disc not geting formated
first of all here is the explanation of what has happened to drive c:
unfotunately the damaged area in your hard drive is in c most probably drive c is unusable any more .
the reason that u see 2 windows xp professional at start up is that there was an incomplete windows instalation in drive c.
i think drive d is safe but since the hard disk is still under warranty i strongly advice you to give it back and get a new one.
Jun 02, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Action shots form my Rebel XT EOS 350D camera
Controls on the top of the EOS 350D are all found on the right side within reach of your 79a8647.jpg
Index finger or thumb.
Select sports icon on it.
Shutter speed is kept as high as possible to ensure capture of fast moving objects and action clips.
Hope its very help full to you
Oct 17, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Intel Motherboard Logo
73 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
