Question about Ovens
Main oven not working on Model Belling 482BL but cannot find spares list for this model. Has it been renumbered?
SOURCE: just brought belling xou594 double
BELLING XOU252 WHEN IT IS SWITCHED ON IT TRIPS THE MAINS ALL WIRES SEEM TO BE GOING TO EARTH.
THANKS
MEL
Posted on Aug 16, 2008
Tomwillfixit
  • 5 Answers
SOURCE: belling no heat in main oven
You need a new element buy on line much cheaper,
Posted on Oct 04, 2008
barkencoa
  • 3463 Answers
SOURCE: belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Posted on Nov 20, 2008
  • 417 Answers
SOURCE: Faulty Oven
Have you tried www.appliance-parts.co.uk, they have a useful parts finder service.
Posted on Nov 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Posted on Dec 13, 2008
My belling wall oven model number 444440560 keeps going out after only a few seconds ignition how can I fix this thNks
which is going out top or bottom? may want to check the oven safety valve though it does not normally go out compared to other components. may have a bad igniter ( does it glow or lite up at all) it may still glow but not put out enough current to ignite flame? check with multimeter as well. if oven top is going out also check the igniter model or infinite switch
Mar 10, 2015 | Belling Ovens
My Belling Synergie 482BL grill blew out yesterday
It's hard to say without actually seeing it, was it shorting out on the bracket that was supporting it? If so, this would be a weak point on the element and as it broke down it could have shorted out to earth through the bracket causing the bang/flash and tripping the breaker. If an element is just touching another metal part it won't short out because the filament is insulated from the casing. You should be able to find the element code on the casing near the terminals. Hope this helps.
Nov 11, 2013 | Ovens
I have a Belling 652BL cooker. The grill and top oven have stopped working, but the rings and the main fan oven continue to work as normal. The troubleshooting section in the user instructions suggests...
ISOLATE MAINS POWER BEFORE OPENING SIDE AND REAR PANELS.
The grill and top oven have as discribed in the manual a temp regulator it is mounted on the side or rear chassis, this is probabily blown, they are normaly connected, when the devise goes faulty it stays open circuit, there are letters and numbers on this, take a note of them if you can read it. go to a local electrical store with the component, you should get a replacement, if however you have a multimeter, measure across the terminals with the meter on resistance, if no continuity, or contiunity to the case, the component is faulty. If however the component checks out working go to timers and remove the time on the auto timer for the top oven, visualy check the elements if the element have Black Grey spot, replace as it has blown, you can get spares at relativly low price you will need model and serial number of the appliance, from whitegoods.co.uk
hope this has been helpful
johnf1
May 17, 2011 | Belling Ovens
My belling oven 482BL will turn on, light comes on but does not heat, what is wrong with it and how can it be fixed?? Really stuck without an oven..
Only two possible causes;
Oven element open circuited and faulty - needs to be tested to confirm;
Burnt wiring at oven element terminals - visual inspection required.
Feb 18, 2011 | Ovens
Fan oven option not functioning on main oven, its a Belling synergie multifunction oven, about 5 years old
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
Oct 24, 2009 | Belling XOU590 Electric Double Oven
How do I find the model number on belling synergie oven?
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
Mar 23, 2009 | Belling XOU174 Electric Single Oven
Dec 13, 2008 | Belling XOU252 Electric Single Oven
Belling multifunction user manual
modle number 44445847
is that all you need?
Jan 06, 2008 | Ovens
Ovens Logo
60 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
