Question about Linksys Wireless-N WRT150N Router
Connectivity we have lan internet connection and shared through linlsys to four computers in one computer i can't get contineous audio through internet
    Problem Solver:
  • 22 Answers
If you are running an ethernet cable to each of the 4 computers (vs wireless), try switching the cable to the computer with a problem to one that is working OK. If this does not switch the problem to the previously working computer then you will be isolating the problem to the one computer instead of the router. Then try uing a new cable to make sure your problem is not there.
Are there other problems with the computer besides audio?
Posted on May 28, 2008
    New Friend:
  • 50 Answers
Is it all the time, or only at Particular Site, is this on all Computers, it can be on the Audio Jack
Aloha
Kahuna
  • Lindsey & Associates
    Lindsey & Associates May 29, 2008
    Have you checked all outlets on the router, or you can just PING Each Computer.. Let me know
    Aloha
    Kahuna
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
Can't share internet over lan
You must share your internet to other computer using your lan connection in able other PC can open internet wondows.To do this
go to my network click set up home and small office network then follow up wisard set up before you close set up insert your cd windows installer e.g. xp or vista click additional task,click home and small office network again from cd follow wizard then click finish,then insert your cd wondows installer to other computer and repeat procedure on set up home and small network restart your PC everytime you install internet sharing,be sure one PC will assigned as server
Mar 06, 2009 | Computers & Internet
How to share internet connection on Windows Vista OS. I want to share internet connection between two Laptops using Windows Vista Operating system and the other using Windows XP. The Host computer is...
All right let's call your Vista computer A and your Xp computer B. First you have to bring the two computers into LAN. If you already did this, please skip the next eight steps.
Step 1: In Vista, before doing this you should enable Sharing and Discovery. You can do that by going to Control Panel -> Network and Sharing Center. Under the section ‘Sharing and Discovery, enable Network discovery, File Sharing, Public folder sharing and others if you want to. (See picture below)
Step 2: If your LAN card that is connecting to another computer is installed, it will be shown under Control Panel -> Network Connections.
Step 3: Right click that local area connection and click properties.
Step 4: Under the tab ‘Networking’, click the properties Internet Protocol Version 4 (TCP/IPv4).
Step 5: Click the radio button to ‘Use the following IP’ and give an IP address (For example, IP address: 192.168.0.1 and Subnet Mask: 255.255.255.0)
Step 6: Don’t give any other information, Click Ok and close everything.
Step 7: In computer B, which is the XP, make sure you enable the LAN card which is used to connect to computer ‘A’. Here you need not give any IP information as Computer ‘A’ will assign an IP address dynamically. If it’s not working make sure there are no IP assigned and change the properties to ‘Obtain an IP address automatically’.
Step 8: Test the connection by pinging. (You can do this by typing ping 192.168.0.1 or whichever is Compter ‘A’s IP in the comand prompt)
NOW your computers are connected. Now to share the internet:
Right click LAN card which is connected to Internet under Control Panel -> Network Connections and click ‘Sharing’ tab and enable both the options to share Internet. (Note: Unless there is another enabled LAN setting you will not be able to see the shared tab under properties)
Click Ok and close. This option is given by the Windows OS known as ICS (Internet Connection Sharing).
Now you can use Internet from both Computer A and Computer B from a single connection.
So this is the setup you need on the Host computer as you requested, if you turn out to need help witht he XP one too, let me know:)
Feb 14, 2009 | Compaq Presario 700 470024-192 Notebook
I have a d link DES-1105. cant get more than one computer to work on hub/switch.
Hi!
Unfortunately, hubs or switches cannot be use to share internet access specially if it's connected to a modem. To share internet access, you will need a router. If you prefer not to use a router, you can enable ICS (Internet Connection sharing) on one PC and share internet access to the others. However, the PC that will share internet access will need two ethernet cards (or LAN cards).
Your setup will look like this:
If internet is not a concern, and you just want to connect the computers to share files and resources, you will have to se your computers to static IP. You do not need any additional device - just connect your computers to the hub, setup a static IP on all the computers.
If you need further assistance setting up static IP on the computers, please reply and I'll give you the step by step instruction for that.
For any setup, a router will be the best option.
I hope that helps.
Good luck and have a nice day!
Nov 30, 2008 | Computers & Internet
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Use a wired router for dial-up (NETZERO) connection..
You want to use a LAN with a router that uses a dial-up as a backbone internet connection for your LAN.
This is absolutely possible.
If you just want to share the connection that one computer has, and dont want to buy a router that has a built-in modem, try this
If you are running windows, There is a feature called Internet Connection Sharing (ICS.) It will share the dialup across the network.
Just 1 hookup the router and all the pcs to it. 2 Dialup the machine with the modem. 3 Enable ICS on that machine. 4 Youre LAN is online.
In XP, goto the network connections, and while you have 2 active connections in there (the dialup and the LAN port connected to the router), right click the dialup, goto properties. goto advanced tab, and click on enable ICS.
The other computers should be served IP's automatically and NAT'd out to the internet by the computer running ICS.
(The other computers should be automatically setup to the internet like they should be and connected to the dialup riunning on the ICS (host) computer)
May 16, 2008 | Linksys (R) RT41P2-AT 4-Port Wired Router...
Internet sharing
which internet u r using
Feb 27, 2008 | Computers & Internet
Internet
There is no utility that comes natively with XP to monitor traffic on an ICS connected LAN. I assume you are not directly connected to the ICS computer, and are running through a Switch or Hub? And you do not have access to this to see how many lines are connected?
If this is the case, you can download and install a packet sniffer and place it within the LAN in front of the ICS computer. It will 'see' all packets traveling across the wire, and report the MAC addresses and IP Addresses to which they are bound. Since every NIC has a unique MAC address (and IP Address), you can see how many computers (NICs) there are in the LAN, and connected to the wire.
http://en.wikipedia.org/wiki/Packet_sniffer
Ethereal:
http://www.ethereal.com/download.html
You can also use a utility like LanGuard Analyzer to search for all computers on the LAN:
http://www.gfi.com/lannetscan/
The last time I checked the trial version is fully operational for 30 days.. I use it in my Corporate LAN to monitor all 1000 computers in my domain.
One other thing to keep in mind, since ICS uses the Class C subnet (this cannot be changed), it has a limit of 254 clients that can be attached.. just an FYI..
Nov 21, 2007 | Computers & Internet
VLAN - and TRUNK
The trunk port of the switch is meant for cascading the switch i.e. you can connect another switch to that port for adding more computers.
For connecting to a multihomed PC (with 2 lan cards) Please type in static ip address to the lan card that is connecting to the switch and alos add static ip adds to all the other computers taht are to be connected for sharing. Then share the internet connection through the other lan card.
Please write to fonix@sify.com for more details
Oct 28, 2007 | Cnet CNSH-1600
Linksys Wireless-N WRT150N Router Logo
94 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
