Question about Windsor SR12 Sensor Bagged Upright Vacuum
MANUAL CARPET HEIGHT ADJUSTMENT WITH # 1 2 3 OR 4. WHICH IS HIGH OR LOW?
  • 8,197 Answers
1 is low 4 is high.
Good Luck and please rate 4 thumbs up and please leave a testimonial
Posted on Oct 03, 2010
The beater brush will no longer drive under a load on short pile carpet
Have you tried changing the height adjustment? There should be a knob or lever that allows you to adjust the height of the beater brush to accommodate different carpet lengths. Even with a new belt, the brush will not spin if the height is too low. Try adjusting it all the way up, then while it is running, adjust it down until there is some resistance. The beater brush should just barely scrape the top of your carpet.
Aug 30, 2015 | Riccar 8955 Upright Vacuum
Height adjustment slips out of low and medium to high carpet position
Owner's manual troubleshooting
no manual? try manuelslib.com
You may have the adjustment device loose look for a screw or bolt to tighten it but not so tight as to stop any movement.
Mar 17, 2015 | Vacuums
White carpet height button flashes
Hi, it's Jack at Dyson.
DC28's carpet height buttons will flash to let you know if you have the carpet height set too low for effective cleaning. Raising the brush bar to the next available height on the selector pad should resolve this.
If you find it continues to flash, it would be worth checking the cleaner head to ensure there are no obstructions. It's also a good idea to remove any threads or hair from around the brush bar:
If you'd like further advice from our experts after giving this a try, please give us a call on 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jul 17, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
White carpet height buttons flash
Hi there, it's Jack at Dyson.
Jul 17, 2014 | Dyson DC28 Animal HEPA Bagless Upright...
Can I fix the high, medium, low level switch on vacuum piece?
The height adjustment lever on Kenmore Power Nozzles is one of the machine's weak points. It's not well made as far as being protected from dirt and dust and moisture. It's always easier to move these things when the vac is on it's side or at least with the front end in the air. That takes the pressure off the adjuster. The mechanism may need nothing more than to taken apart in the presence of a good air compressor which can be used to blow out any of the aforementioned debris.
Nov 11, 2013 | Kenmore Vacuums
Height Adjustment on Hoover Wind Tunnel doesn't seem to do the job.
You changed the belt that drives the brushroll, it is a flat stretch belt. The V belt also should be replaced every year or two max. It will not be stretched out like the flat belt but with normal use the side of the v will of wear off and the belt will be a little thinner which can cause it to slip on the pulley. The V belt drives the transmission. The flat belt goes from the transmission to drive the brushroll. The burning smell could come from the V belt if it's slipping real bad.
Mar 15, 2017 | Vacuums
Vacuum height won't go on low carpet setting. Dial will go on medium and high, but not low.
Make sure you're not trying to adjust w/ handle in upright locked position because thewre is a cam which raises the vacuum head a little bit when handle is locked in upright position. If this is not the problem, turn vacuum upside down with handle in unlocked position and power cord not plugged in(for safety reasons obviously), unscrew and remove 3 screws that hold belt/beater brush assembly cover in place(2 are in corner near ends of beater brush and 1 is towards motor housing) tilt end of cover with 1 screw up and remove cover(there are 2 tabs at beater brush end of cover). Right above this is the height adjustment assembly with 2 rollers, raise up the assembly gently and using your finger or a bristle bottle brush,etc. make sure there is no debris caught between the height assembly and the hose(you will understand when you see it), if there is no debris you can now see the pattern on the bottom of the height adjustment knob and the lobe that rides on it, just check to make sure nothing is broken and/or missing, hope this helps!!
Dec 29, 2009 | Hoover Vacuums
My brushes wont turn once the vacum is on the carpet.
If they are turning when they're off the carpet, then you have the brush height setting set too low. There should be a dial somewhere near the brushes, some say things like "high" to "low" or "high pile" to "low pile." Turn it one notch towards high/up and try it again, and keep turning one notch and trying until the brushes turn. You want them as close to the carpet as you can get them without them stopping. If this doesn't fix it, you have to be more specific as to whats going on.
Aug 19, 2009 | Dirt Devil Vacuums
Height adjustment on Hoover Windtunnel u5755-900 no longer works
On this model it is only a single slide adjustment lever. have you trie to tilt the vac backwards (lifting the wieght off the front wheels) and then slide the adjustment lever?
If there is a mechanical issue with it. take the bottom plate and roller out, and then the 2 small screws which hold the cover on underneath. you should be able to see the problem from there
Jan 10, 2009 | Hoover Vacuums
Kirby creating dirt under carpet?
It is possible that the height adjustment on your Kirby is to close to the carpet,which could account for the problem you're having.The correct height adjustment for your Kirby is this-Lower the height adjustment down until you hear a change in the sound,then adjust one more click down.The Kirby is at the correct height for cleaning.If the carpet is different in another room,adjust it the same way for each carpet
Dec 15, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Windsor SR12 Sensor Bagged Upright Vacuum Logo
133 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
