Diagram of wireing for heating element in a colman package unit model no PAC036H 1021A
2 Suggested Answers
  • 69 Answers
SOURCE: wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Posted on Dec 21, 2008
Wire diagram dgato75bdc
Request the wiring diagram directly from Coleman.
Nov 22, 2017 | Heating & Cooling
I have a colman furnace one element stays on constantly can you tell me why
Furnace is the term we use for a gas system. I'm assuming you have an electric "air handler"(unit), and or has 1 element staying on, glowing red, and cycling on a limit. These elements are controlled by "heat sequencers", heat relays, and some older units used heat contactor's. This "switch" is stuck closed & must be replaced. I've also seen a direct short at the element itself, where the element has come apart, and a part of that element had touched ground. This completed the circuit and allowed the element the energize. Hope this helps! Its probably a stuck (closed), switch that's supposed to open when the tatat is satisfied.
Feb 21, 2017 | Heating & Cooling
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
No heat need a wireing diagram 1997 package unit
impossible to get wiring diagram without model or manufacturer
Nov 21, 2009 | Heating & Cooling
Old a/c package unit add on heat
check your wiring coming from the thermostat should have 24 volts at common terminal and W terminal W is usually used for the heating side. once this is working check to see if you have 24v between common and G which is usually used for the fan motor. if that is good make sure you have full high voltage going to the motor itself find its wires and where they are connected. if it was a low voltage issue and you dont have the 24 volts somewhere in there i was talking about try rewiring the system according to the OEM wiring diagram. You can probably get one on the internet if you google your model number off the unit and its make.
Sep 20, 2009 | Weather King 10AJA2501AH Air Conditioner
I have a colman electric furnace eb15b it had a/c.i am using it as a furnance only.i used the white red wire for thermostate.it works but not great.blows hot for a short time.then warm only.takes a long...
You need to make sure that both sides of the heat kit are coming on. One of the heating elements could be bad. Turn the power off and remove the heat kit. Check and see if there are any visible breaks on it. Also, when the unit is running, take a volt meter and check for voltage to the heat kit. You can also do a continuity check to see if the heating elements are good. Good luck.
Feb 18, 2009 | Heating & Cooling
Roper rex5634pqo wont heat. Need diagram. dont know location of components.
i think this unit has a lint filter that pulls out the top of the unit. if so then your heating element is in the back and has 2 red wires going to it at the bottom of the element. unplug the unit and remove the element and check it to see if it is broke. the element needs to be in one piece.
if it is good, then check the thermostats that are mounted on the side of the element housing. one at the top and one right by the lower wiring. the thermostats are available in a package with both and those are most likely what is wrong.
Dec 06, 2008 | Kenmore 63942 Dryer
INSTALL HEAT TO A INTERTHERM
Wiring diagram is normally included and fixed to the inside cover of the electrical end cover of the control compartment. Instructions for wire size required and fused disconnect should be on the unit name plate.
Nov 09, 2008 | Heating & Cooling
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
