Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error code 6A00. Alarm light flashing and not able to print
  • Canon Master
  • 4,737 Answers
Error 6A00 has no specific cause and no specific solution/fix. Sometimes, it's cause by Paper Jam, sometimes Waste Ink Tank Full, sometimes Carriage Problem and still many more.
Simplest Trick: Open the front cover, pull the cartridges with the carriage and leave them somewhere on the passage, now close
the cover and turn off the printer, again turn it on. If it's not a fatal error, there'd be no more problem and no more error displays on the screen.
First try this, open the hood (front cover), after the cartridges moved towards the other end/side, look at the other side (the
side where the cartridges were sitting before it moved to the other side). You'll see the Waste Ink Tank Pads (sponge), remove
them and clean them (they should have been soaked with ink, so use a hand-glove). Remove the pads and squeaze or wash and dry them, after they are cleaned and dried, reinstall (re-seat) them. Now power on the printer and check again.
Secondly, (remove the cartridges before you begin) open the doors and look for paper jam or anything inside the passage and through the paper passage. Use a blower to blow all the dust and clear them out. Now turn off the printer and leave it for few minutes while you clean the cartridges, again switch on the printer, install the cartridges. Now see if it's still there or not.
Try turning the printer up-side down, shake it (do this while the machine is off) and again reboot it. Once again check the status.
Push in a photo paper (or similar thicker paper) into the sheet feeder, do this several times and again reboot the printer.
If the problem even after all these are done, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 03, 2010
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Printer stopped working. I just added new ink supply. Alarm light flashes. Printer status says "service error 6A00"--"check printer" "cancel printing and press the ok button." None of this works. And I...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Apr 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Receiving error code 6A00, and alarm light is
That error says the purge unit is broken. You will need to have the purge assembly replaced.
It's # QM2-3032-000 but a shop should replace it for you.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error Code 6A00 and flashing alarm. Paper stuck
Hi
All the best
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I recently added a router and now when I try and print it comes up an error code and the copy light flashes along with the alarm light
Need to know the error code, that one is famous for the 6A00 error that you need a new purge assembly. Probably not related to the new router.
Oct 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Alarm light flashing and a 6A00 error code
Ok try this
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Sep 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My MP830 has an error code of 6A00. The assembly
6A00 means the purge assembly is jammed or worn out. Part number QM2-3032-000 around
$30.00. It's the cleaning assembly on the right where the printhead parks when shut down.
Jul 01, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Alarm light is flashing and can not print
Hi
Try this
Solution 1:
Solution 2:
Solution 3:
Nov 12, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 12, 2008 | Canon MP830 All-In-One Printer
Error 6A00
Solution 1:
Solution 2:
Solution 3:
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
81 people viewed this question
old marine
old marine
