Canon MP540 Front flap on output tray will not stay closed, there is round spring loose in the bottom LH corner but I cannot see where it has come from
nk_07
  • 154 Answers
SOURCE: Canon Pixma 4300 complaining that
its due to some mechanical fault.
you will have to dismantle the unit to find the exact fault.
thank you
Posted on Oct 21, 2008
ic0729
  • 212 Answers
SOURCE: canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Posted on Mar 19, 2010
SOURCE: MX338 output tray problem,
please help me...how to reset the following ink cartridge cannot be recognized U051 canon mx338
Posted on Apr 14, 2010
SOURCE: paper output tray closed
how do i transfer the ledger only from 1.4.09 to 1.4.10
Posted on May 08, 2010
  • 252 Answers
SOURCE: When ever I try to
Jilar,
Is the front tray down? That is the document output tray and it will detect an error if it's not down.
Posted on Mar 23, 2011
How to load envelopes in a canon mg3250 printer
Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif You can only print on envelopes with the computer.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive Prepare envelopes.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Press down on all four corners and edges of the envelopes to flatten them.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the corner of the envelope flap is folded, flatten it.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm). Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides. (5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Be sure to open the paper output tray when printing. If not open, the machine cannot start printing. After loading envelopes
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image003.gif Select the size and type of the loaded envelopes on the print settings screen of the printer driver. You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
Nov 13, 2014 | Canon PIXMA MG3250 All-in-One Inkjet...
How to install sim card
1. Slide battery door switch from locked to unlocked.
2. Remove battery door by prying up in the notch are that is provided in the bottom corner.
3. Slide battery lock switch to unlocked position ( this is located at the bottom of the battery and slides from left to right or right to left depending on if the device is locked or unlocked.
4. Remove battery from the device.
5. In the bottom left hand corner you will find a small metal tray that has a rubber flap covering the front of it. Pull up on the rubber flap ( it stays connected to the phone ).
6. Look for the SIM card picture to show the correct orientation of the card.
7. Slide the card into the metal tray and the replace the rubber flap by pressing down on it firmly.
8. Replace battery and slide battery lock switch to the locked position.
9. Replace battery door and slide the battery door switch to the locked position.
Jul 11, 2014 | Casio G-zone Commando
Mijn Canon MP540 geeft in het display error 6C10. Wat is hier aan te doen? De papierlade is bijgevuld en inktpatronen zijn vol
not the printhead
clean the ink absorbers located at the right side
bottom remove them and put them in can with water
also the transparant flaps in front of the absorbers
Sep 19, 2011 | Canon PIXMA MP540 All-In-One InkJet...
JVC Model DR-MV99 tray door keeps opening and closing when trying to insert a DVD disk
This problem was driving me crazy, until I found a solution.
This is what you need to do.
When the tray is open grab the flap door that goes up when the dvd goes in. Hold it down as you the DVD tray goes in. (Its spring loaded) This allows you to have direct access to the front of the tray even when the DVD goes all the way in. Hold the tray in with your finger by pushing in firmly on the far right corner of the DVD tray. The DVD tray will try and come out, continue to hold it in while pressing the eject button on the remote. If you are firmly pressing in on the right corner of the tray it should only take a few times of pressing eject when you see the Disk symbol on the screen and you will here the DVD start loading. When you know that it is starting to load release the front door flap. You can then use the DVD player as normal.
Unfortuntely you will need to do this each time a DVD is loaded.
Jan 24, 2011 | JVC Televison & Video
I have Canon pixma MX310 and I just trying to set it up.I'm trying to print and there is message open paper out tray.What is that mean and how I can fix it
The printer will not print as long as the paper output tray is closed.
  1. Open the Paper Output Tray (2).
    Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
  2. Open the Output Tray Extension (3).
    Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
  3. Adjust the position of the Paper Thickness Lever (4).
    Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper.
Oct 29, 2010 | Canon PIXMA MX310 All-In-One Printer
My printer keeps printing from rear tray when i want it to print from the cassette. all settings for the print are set to cassette printing, and yet it still insists on trying to print from the rear. It is...
Most of those have a button marked feed switch and a picture with a LED that either shows rear or bottom tray. You need to select the right tray on the printer panel.
Oct 30, 2009 | Canon PIXMA MP540 All-In-One InkJet...
Canon MP540 Error 6C10
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Oct 21, 2009 | Canon PIXMA MP540 All-In-One InkJet...
PRINTER SYSTEM STATES INNER COVER NOT CLOSED - WILL NOT PRINT
If you look in the middle of the paper output tray you will see a flap door appr.6inches long.This is for CD printing which is not enabled in the US .Just make sure that the flap is closed.
Aug 04, 2009 | Canon PIXMA MP610 InkJet Printer
Coin Tray Wont Stay Closed
The plastic spring clip had become stressed and had "moved" out of position resulting in no "retaining presure,hence the coin tray/fuse cover would not stay in the "Closed" position."Simple" $6.75 fix.
Dec 29, 2008 | 2002 Subaru Forester
How to clean the bottom filter
Don't know how old your machine is but on my wtl5400 the bottom flap is opened by:
1. open the drier door
2. note small round button on the lower right hand side of the drum surround
3. press the button which will spring forward then
4. lower filter cover springs off giving acess to filter drawer
NB if the filter is over full the button will spring open itself as a gentle hint
NNB YOU CANNOT CLOSE DOOR WHILE THE BUTTON IS EXTENDED so take care door will only close when lower cover has been correctly replaced relocating the button flush with the front of the machine
Aug 28, 2008 | Bosch Axxis WTL 5400 Dryer
44 people viewed this question
jasbo
jasbo
