Question about Samsung Washing Machines
Samsung washing machine error TE appears part way through wash. Does not appear to be temperature related as it's nearer the end of cycle? Do you know what this error relates to?
  • 1 more comment
  • smwaverider May 28, 2008
    Thanks for the solution. Lose wiring, now fixed, Keep up the good work,
    Steve
  • FartyFastGuy Apr 02, 2013
    How did you fix the wiring? How to take the whole thing appart!?
    Access the machine from the bottom, there youll find the weight stone and next to it the wirung. In my case, the stone was losened also, it is fixed with plastic, whch means its made to break out at some point.
Thermistor error, so actually it is temperature related. the thermistor is located at the bottom of the tub asm. with the heater element. check wires and replace thermistor. the tech paper in the washer may give the proper ohms to check it with a meter.
Posted on May 28, 2008
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
I'm getting error code tE on samsung silvercare WF316LAS/XAA
tE is mostly related to
temperature sensor wire and connection problem. Look for a broken or loose wire.
Dec 07, 2012 | Washing Machines
Hi i have a error coming up on my main cycle E5 Quickwash 30degrees on my washing machine. It is a Samsung WF7600NAS . its not spinning, i have drained and cleaned the filter> please help
'E5' for all Samsung washers decodes as 'water temperature rising/falling too quickly. Check thermistor'.
That, to me, means a service call for you I fear ;-0(
Sorry that we appear to be of no more help remotely on this occasion.
Good luck,
John C
Mar 16, 2011 | Samsung WF337AA Front Load Washer
Getting "te" error message - help!
'te' stands for Temperature Error in most LG washers I suspect; the water is not being heated. Probably the heating element is malfunctioning and it would appear you will need to make a service call ;-0(
Good luck,
John C
Mar 04, 2011 | LG Washing Machines
Washing machine error code is tE, something to do with the power?
tE stands for Thermistor Error. This is a problem having to to with the water temperature, possible causes are: water heater was low on hot water, or the thermistor gave a faulty reading. It can be corrected by unplugging the machine for 10 minutes and restarting the machine.
If this helps you please rate my solution.
Thanks, Repairman45
Dec 02, 2010 | Samsung Washing Machines
Error number 2 appears on Hoover AAA whisper 1400 washing machine - any help? When it appears which is becoming more regular that it use to be I usually end up putting the washing through a quick spin,...
I downloaded the manual from Hoover website. Error number 2 relates to the washing machine not filling up with enough water. Check the water supply and correct angle of the pipe.
Sep 15, 2009 | Washing Machines
Code EC appears on my washing machine few seconds after started
Ec indicates a problem with the thermistor or temperature sensor.
Repair and service your own washing machine.
kindly check them out....
thank you have a nice day
Jun 02, 2009 | Samsung Washing Machines
Washing Machines Logo
1,025 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
