Question about U-Line 2075WC Wine Cooler
I'm not getting any cooling with a 2075 WCS wine regrigerator. Completely shut down. The light is on so its getting power. Have had the unit for 5 years and not had an issue.
    Sergeant:
    Champion:
  • 351 Answers
Check thermostat
Posted on Oct 03, 2010
  • Wally-Tonya Czyz
    Wally-Tonya Czyz Jun 26, 2014
    How do you check the thermostat? What's the process to verify that it's no longer functioning?
Uline wine fridge 2075-wcs not cold enough
Check condenser make sure it is clean then listen to see if condenser fan motor is running . if compressor is running cuntinuesly and other mentioned are ok it could be low on Freon
Nov 08, 2012 | U-Line Refrigerators
Ice on the back wall; temperature went from 58 degrees to 34 degrees; had to shut off regrigerator
hi,
Wine cabinets work off of cycle defrost, so in order to built frost your temperature sensors are not working properly. I would look for corrosion on or in connections to be the fault or problem. Sensors report information to control unit and thats there only job. Its the control unit that dictates function. Look for corrosion to be the problem, clean connection and seal with RTV when connection a corrected.
Good Luck
Sep 10, 2011 | Transtherm Ermitage Wine Cooler
Wine cooler has no light or power working it simply shut down
you want to check power coming into unit... do you have power at the switch... there was alot of issues a ton etime with there power control switches and thermostats... check incoming power to unit and see if the switch has failed... also these units have small controls on them that will fail from time to time. you are going to have to see where power has failed at.
Jan 03, 2011 | Avanti EWC28 Wine Cooler
Unit has been operating in a wine closet and just stopped working it there anything I should check or clean? swaney167@aol.com
does the 'closet' have any ventilation? if not the unit could have overheated and shut down or , worse, burned up the motor. any 'electric smell to it? under the unit, should be a fan, it that stopped it will not cool. look for lint build up under the unit or around any air vents. How old is the wine cooler? can you get any info from the Wine cooler's mfg web site? www.danby.com/products/wine__beverages -
Dec 26, 2010 | Danby DWC440 Wine Cooler
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Jul 20, 2010 | Haier BC112G Wine Cooler
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Nov 04, 2009 | GE ZDW24A Wine Cooler
Vinotemp VT-16TEDS has light on but doesn't cool
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
May 30, 2007 | Danby DWC283BLS Wine Cooler
U-Line 2075WC Wine Cooler Logo
312 people viewed this question
Top U-Line Furniture Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
