Question about Microwave Ovens
Manual for neff hft759 - how to remove oven cover
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Neff Combined oven and microwave
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Nov 09, 2008
Is the light cover screwed or a push fit NEFF oven
are you sure its not a
Neff H5642N0GB why you wanting off? has the bulb gone? you can take the hole top off to get to the bulb, make sue you unplug it...not just switch it off ! i mean unplug it from the wall !
Oct 06, 2014 | Neff H5642 Convection / Microwave Oven
I need instruction manual for Neff microwave oven model 5969
Use link, enter full ENr from rating plate and you can download PDF of manual
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Dec 08, 2012 | Neff Microwave Ovens
Hot air function not working
If it's not addressed in your owner's manual, you will need to take the cover off the oven to find and replace it.
The owner's manual will also give you contact information for your manufacturer so you can contact them to find local or nearby parts distributors.
Dec 20, 2011 | Neff B7740N0GB Microwave Oven
How do i remove the cover to change the light bulb inside?
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Nov 20, 2010 | Neff H7871 Convection/Microwave Oven
My Neff 900 is not working and displaying the H95 code .... what's the problem ?
It's nothing more than the door catch, remove the outer cover and adjust the switch. it's on a slot and that moves out of position. just pull it back in position ans nip it back up. simples!!
May 29, 2010 | Neff H5470 Microwave Oven
Replace light bulb on the Neff H7871 combined oven and microwave.
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Neff microwave h7871 arcing
This antenna is called the stirrer here in the US. Its purpose is to stir the microwaves to ensure even cooking.
The cover is usually made of plastic, as opposed to ceramic, and it keeps grease and food particles off the stirrer to protect it from arcing, which can damage the surfaces and the magnetron.
The stirrer, stirrer cover and the area around it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available in appliance parts stores and hardware stores.
Also, the stirrer will arc if it is not turning when the oven is cooking. That may mean a bad stirrer motor.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron and stirrer.
You can download Neff manuals here.
Even if you don't find your exact model, they should all have contact info for Neff in case you need to call them to get spares / parts.
Dec 13, 2008 | Neff H7871 Convection/Microwave Oven
Nov 03, 2008 | Neff H5470 Microwave Oven
Changing the light bulb
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Aug 20, 2008 | Neff H7871 Convection/Microwave Oven
Interior light gone out
There is usually a little window inside that might remove with screws, or even snap in. That should allow access to the lamp. Check the manufactures website under product support for more info.
Jun 24, 2007 | Neff H7871N2GB Convection / Microwave Oven
Microwave Ovens Logo
575 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
