Owners manual for luxaire model gm9s060b12up11g
I need a wiring diagram for a older luxair standing pilot propane furnace no model number but has a control board with a standing pilot
Holy moly man! Time to retire that old girl and install something more modern, more efficient...and safer!
Jan 28, 2018 | Heating & Cooling
I have a luxaire gas furnace and the gas valve keeps opening and closing. no codes when valve not connected, the voltage stays 24 volts. connected it drops out constantly
hmmm it seems like the luxaire furnace isnt able to tell if the valve is open or closed by electronic means try replacing the part and see if it helps
Dec 05, 2016 | Heating & Cooling
I have a luxaire condenser and its so old that model # is gone but i have the serial# efrm155233 can anyone tell me the tonage?
It is not measured in tons. measured in BTU'S British Thermal units. there is a plate on it telling all this info.
May 15, 2015 | Heating & Cooling
Where can I find a wiring diagram for a luxaire furnace model number SSL110MS
Google your model number there seems to be a few out there.
Oct 09, 2014 | Heating & Cooling
R22 refrigerant charge how much on luxaire heat pump model LHJA18FS-AAA
hy mai name is tibi
solution is to upload up of 4.2 bar on thick pipe (gas pipe)
but you have to make sure the condenser is clean
good luck
Mar 07, 2013 | Heating & Cooling
I have an older Luxaire furnace: Model # GSU137FF Serial # NAJTE Input 137000BTU out 110000Btu Natural GAS. What is age of unit, are parts available, whats is its efficiency rating. Should I fix or...
Your effeciency rating is 80%. Divide your output capacity 110,000 by your input capacity 137,000 and that will give you your effeciency.
The manufacture date is usually in the serial number.
You need to go to Luxaire.com and they can answer that question for you.
As far as parts there be parts available.
Fix or replace, if you are happy with the equipment and not really having a lot of problems, you may want to keep it. The newer equipment is more efficient, so if you think your gas bill is to high or you want to save some money on your gas bill, you may want to replace it.
Apr 09, 2010 | Heating & Cooling
What ton is my old Luxaire AC unit? it is model EESQ36
Sure but you need ot have an AC man to replace it and vac down the system plust change the dryer/reciever.
Jun 12, 2009 | Weather King 10AJA3601AH Air Conditioner
Heating & Cooling Logo
188 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
