FixYa.com
Tags:
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
Problems with sending documents in Panasonic...
posted by Mayoite on May 27, 2008
I have an old Panasonic KX-F2781BX Plain Paper Thermal machine that I bought ten years ago. When I send documents, they are not coming out readable on the other side - the printing is too faint or not legible. I tested the copy function on the machine and I'm having the same problem. Can you please help with this ?
Comment by Mayoite, posted on May 29, 2008
Actually I had an engineer come in to take a look at it and he said that the scanner needed replacement. Given that the machine is over 10 years old, I guess it's not surprising. Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 28, 2008
Thanks for Trying (70)
lbcoaster
Rank:Guru Guru
Rating: 92%, 65 votes
Sounds like there may be a problem in the optics, the mirrors under the **** glass and both sides of the **** glass should be cleaned first...
Rating Locked! (?) Mayoite has rated this solution as Thanks for Trying
Solution #2
jimmac123
Rank:Apprentice Apprentice
Rating: 81%, 4 votes
Probably a fault with the thermal print strip. or the print strip may just be dirty, in which case you could clean it with a cloth and some alcohol.
Can you Help with these Fax Machines problems?
Fax Machines
TFT LCD display Model name
tft lcd display model name... Answer This...
Panasonic KX-FHD331 Plain Paper Thermal...
kxfhd panasonic fax/printer
prints only 1/4 page. replaced... Answer This...
KX-FHD331
keep getting a message stating... Answer This...
change from letter to A4
This fax only works with letter... Answer This...
Panasonic Cable?
Dear jaylex Thanks for the... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
