Question about Samsung Refrigerators
Fridge Fan noisey, Fridge temperature suspect and water dispenser works intermittantly. Model is the RS21DABB and was purchased in November 2006
  • 999steve Feb 14, 2009
    i have the sound of the fan extremely loud and will stop when the door is opened can anyone help? sounds almost as though the fan is catching on the plastic cover?? please help
  • 828 Answers
Fan motor bearings bad if it is a high pitched noise. If the fan is not running up to its full speed it will affect the refrigerator temperature.
Posted on May 27, 2008
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Dec 04, 2012 | Refrigerators
GE Profile PFSS5NJWA SS water dispenser not dispensing water. I tried changing the filter, but it still does not work. I also tried pressing the "reset filter" button. When I press the water...
We have the same model and just had exactly the same problem. The coil behind the fresh produce trays is frozen. There are 2 coils, one provides water for the water dispenser and the other to the ice maker. Looking into the fridge the water dispenser coil is on the right hand side. We unplugged the fridge for a couple of hours and the problem has been solved. Try increasing the temperature of your fridge by a degree or two.
Feb 17, 2011 | General Electric PFSS5NJXSS Stainless...
RS21DABB- water dispenser will not dispense anymore. Mechanically intact but no flow! Rest of fridge/freezer perfect!
no water can be the early signs of the common issues with samsung rs21 models
what happens is the fridge cooler /defrost system goes faulty and freezers the water instead of chilling it , the best way to check is to take the 2 drawers out the bottom section of the fridge you will then be able to see the water bottle , if there's a lot of ice around the bottle then this would confirm a defrost issue , you can heat the bottle for 10 minutes or so with a hair dryer etc , if the water starts to work after this then you probably will have to call an engineer or fit the rs21 diy fridge repair kit
this video may help
Dec 17, 2009 | Cell Phones
Need owner manual for POLAR water cooler with fridge
how do i set the thermostat on my polar water dispenser.model#PWD335-
Sep 25, 2009 | Kitchen Appliances - Others
Freezer and fridge tempeture increasing.
The black " tank " is the compressor . Will the fan by the compressor run ? If not , that is the problem ( fan motor ) . Are the coils clean of dust , lint , pet hair , etc ? The brand and model number would have helped . Since the compressor is hot , means it should be good . The fan motor must be working , to help keep the compressor cool . Also , the back cardboard or metal panel must be in place when finished , or the fan will draw outside air instead of front air over the coils and compressor .
Aug 30, 2009 | GE Profile Arctica 25.4 Cubic Feet...
FROZEN WATER FILTER - UNRELIABLE TEMPERATURES
About the dual water control valve the side that feeds the ice maker could be defective. Fill the ice maker with tap water and let freeze. If it dumps and does not refill the water control valve will need replaced. Here is a link to the water control valve.
WR57X10032 Water Control Valve
As far as the temperature control here is a link to the Temperature Control Here=>
WR55X10095 Temperature Board Encoder Below are some photos. If I can help answer any questions let me know, Sea Breeze appliancepartsse@yahoo.com 6b49f39.jpg053ba1a.jpg
Jul 28, 2009 | GE Profile Arctica Stainless Steel Top...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Refrigerators Logo
300 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
