Question about Sharp LC-32SB23U 32 in. LCD TV
Have 32 flat screen tv, want to transport it to new location, will take 3 days, can i lay in on its back?
  • 8,197 Answers
I would not recommend you ship it on its back you might break the screen. I would ship standing up.
Good Luck and please rate 4 thumbs up and please leave a testimonial
Posted on Oct 03, 2010
Can I lay a samsung led tv flat when transporting
Yes you can, but be sure to put down a thick blanket and put the face down so the screen will not be scratched. Lying one down will not affect the picture whatsoever when you set it back up
Jul 25, 2011 | Televison & Video
I need to replace my table top stand for mySony 32 inch Model # KDL 32S3000, can you guide me in the right direction
The instructions are in your USER MANUAL found at the following link:
http://www.docs.sony.com/release/KDL32SL130.pdf
In general though you should lay the tv screen side down on something VERY soft and flat like a bed so that the screen doesn't get scratched at all.
Then find the 3 philips head screws that hold the base to the tv. They should have replaced into the proper holes in the back of the tv when the base was removed initially. Unscrew and remove them and then place the base into position on the tv.
Once the base is fitted into position, insert and tighten the 3 screws again. The tv can now be lifted vertical again and placed where desired. Be sure not to press too hard on the actual LCD screen part when handling.
Good luck and post back how you make out.
Jan 23, 2011 | Televison & Video
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
Instructions:
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
I have a lcd tv .unfortuntly my son trow in a pece of qubik shuger on flat tv ,after 3 days it show a dark line ov tv . pleas gud mme.
maryam_edesa, Unfortunatly once they the screen panel is damaged it cant be repaired. the only thing you can do is replace the screen panel but it would cost more than a new tv.
I would suggest you use it untill dies byitself.
Aug 27, 2010 | Samsung LN32B550 32 in. LCD HDTV
I wish to move my Panasonic Vieta to another address.
I would wrap a thick cloth towel, blanket or comforter around the screen and lay it face down (screen down) on a flat surface, making sure the TV will non move in any way. If you transport it face up, there may be a chance that something may fall on the screen and damage it.
Jul 17, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Transporting a flat screen.....
Yes, it can be layed down. Just be sure it is cusiond well and does not slide around. Sliding could scratch the screen.
May 14, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My Sony trinitron model number kv32hs500 were is the
If you take the TV and lay it flat on its face, then you will be able to get the whole back cover off. Once the back cover is removed, and with the TV still on its face, there will be some a large circuit board sticking up in the air from what is normally the bottom of the TV. At this point you may want to tip the TV back onto its bottom (so the screen is showing again). Now, on the right side of the circuit board, near a couple things that look like large batteries sticking up, will be the two IC chips. They are about an inch long and maybe half an inch wide. They are only a couple inches from each other. Hope this helps you locate them.
Apr 10, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
I need to know if it is possible to transport side by side refrigerators laying flat. or almost flat. This will be a short move for about 1/2 hour.
Hello, Yes you can move your side by side laying on it's back..it is most important though that when you have it in it's new place you leave it unpluged for 24 hours so the oils can run back into the compressor. If you have any other questions please feel free to comment again...Mike
Aug 24, 2009 | Refrigerators
I have a 50 inch big screen hdtv and i am moving i want to know can i lay my tv down flat?
Yes you can lay it down flat on its screen just make sure it is padded so the screen doesnt get scratched. I transport projection units this way all the time even DLPs however do not transport LCD or plasma units in this manner as thats not recomended.
Mar 30, 2008 | Televison & Video
New 26 hd tv just out of the box
Send back, say damaged in shipping, if you transported it then damaged on floor.
Aug 13, 2007 | Vizio L32 32 in. LCD HDTV
Sharp LC-32SB23U 32 in. LCD TV Logo
48 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
