Question about HP LaserJet 5mp Printer
On HP 5MP laserjet Printer, on printing a document, the message says: the printer requires more memory than is avaailable in this printer.what to do then?
    Genius:
  • 1,089 Answers
You don't say what kind of a document you are trying to print. Did you try to print something else. Did it print?
Normally if you try and print a complex spread sheet you may get that warning. You have the option of adding more memory or making your print job less complex. Or printing to another printer.
Posted on Oct 04, 2010
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    Insufficient memory
    This error occurs when the onboard memory is not sufficient to print the file you are sending. This can be caused by either a file that is too complex for the memory that shipped with the printer. Unlike other models of HP, the 3030 does not share memory with the fax so it is unlikely that faxes stuck in memory are causing the problem. If the printer prints other documents ok, then it is just the reality that newer programs create files that require printer memory that far exceeds what this older model printer has.
    Aug 16, 2014 | HP LaserJet 3030 All-In-One Printer
    How to fix sensor error on hp color laserjet 2600
    54.06
    Error message
    54.06
    Description
    Color density sensor error
    Action
    1. Power cycle the printer.
    2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
    3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
    4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
    Apr 02, 2014 | HP Color LaserJet 2600n Printer
    5P/5MP only prints to back tray now.
    Face the printer. Lightly put a finger on the rollers at the back of the printer where the paper exits the printer while you are printing. If they arn't turning that's why the jams. A tech will probably have to look at it. That is the "face down delivery assembly"
    Mar 15, 2014 | HP LaserJet 5mp Printer
    Pcl xl error error: insufficient memory operator: rectanglepth position : 751 How do i correct this problem
    Solution
    The possible reasons for this error message are as follows:
    • The document is containing both image and text.
    • The font is not supported.
    • Embedded fonts are used.
    • A special plug-in is used.
    This issue can be fixed by enabling the following option in Printer Preferences .
    To access Printer Preferences , follow these steps:
    1. Open the Control Panel .
    2. Open Printers and Faxes .
    3. Right-click HP Color LaserJet CM2320 MFP Series PCL 6 , and select Printing Preferences .
    4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
    5. Now try printing the document.
    6. If the document did not print then try turning the printer off then back on. Try printing the document again.
    Rameshkumar . R
    cberamesh@gmail.com
    Aug 24, 2011 | HP LaserJet P2015 Printer
    My HP Colour LaserJet CM1312 has refused to print a one page document which has a few boxes on it with coloured pictures and writing. This has never been a problem on any other printer. It printed out an...
    If you edit the photos and save them at a lower resolution, then put the lower resolution photos into the document, that's the quick fix.
    A program such as photoshop or corel photopaint are able to do this quite easily. In corel for instance you simply resave the photo as a jpeg, and it'll ask the resolution/quality etc. and you can reduce the resolution usually quite a bit before you lose any quality in the printout.
    The other solution is to upgrade the printer's memory.
    Inkjet printers usually will not have this issue because they don't need to form the complete page in memory before printing like a laser printer does. An injet's image is formed line by line in the print driver and then streamed to the printer, so the printer's ram doesn't have to take the whole page at once.
    Mar 25, 2011 | HP LaserJet CM1312 All-In-One Printer
    I have an HP Color Laserjet 3600n with error 10.10.03
    Thank you for contacting FixYa with your printer issue.
    www.hp.com Support Document (110993)
    10.XX.YY SUPPLY MEMORY ERROR Description The printer cannot read or write to at least one print cartridge memory tag, or at least one memory tag is missing. Action
    1. Open and close the front door.
    2. Remove the print cartridges, and then reinstall them.
    3. Close the front door.
    4. Turn the printer off and then on.
    5. If the error persists, contact HP Support.
    Helpful CLJ 3600 Error Message Tables:
    http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478&prodTypeId=18972&prodSeriesId=501044
    Hope this helps helps. Please keep us updated and remember to rate this answer.
    Jan 22, 2011 | HP LaserJet 3600n Printer
    LaserJet 5MPHP
    Only if you print the first side then place the paper back into the printer to do the second side. Also referred to as manual duplexing. This printer has no automatic duplexing option.
    Also keep in mind that the percentage of duplex prints you do should be very low as this printer has no method of cleaning the fusing unit as most printers do that are made for duplexing. The industry standard is 2% or less should be duplexed.
    Jan 05, 2010 | Office Equipment & Supplies
    Not enough memory LaserHet 6mp Printer HP
    Donna,
    Yes you can add more memory to this printer. It slots into the formatter (under left side cover)
    Memory upgrades
    1 MByte—C3130A
    2 MByte—C3131A
    4 MByte—C3132A
    8 MByte—C3133A
    16 MByte—C3146A
    Add up to 32 MBytes of memory to the HP LaserJet 5MP/6MP printers, for a total of 35 MBytes..
    Dec 30, 2007 | HP LaserJet 6mp Printer
    HP LaserJet 5mp Printer Logo
    203 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
