Question about Hawking HWREG1 Repeater
Local Only Laptop is finding a good signal but most of the time comes up saying "Connected to the Intertnet Local Only" meaning you can'y actually access the internet. Any tips as to why and how to fix it? Thanks
  • Somerled Jun 01, 2008
    Still having the problem as the gateway address doesn't seem to be working. I'm using 192.168.0.1 or 192.168.1.2 but neither seems to be correct. As you may gather my technical knowledge isn't great!
  • nonplusultra Nov 20, 2008
    HWREG1 setup says that the access point is 'out of reach' or that the passphrase is incorrect. Both is not true, I can't see why it is not connecting.Odd, because it did work before.
    Problem Solver:
  • 5 Answers
I have a similar problem.
I setup the extender with an IP that doesn't conflict with the main router (a Netgear DG834GT).
I have MAC address filtering setup; the extender has permission to access the Netgear, and vice-versa, yet when I eventually save all the settings, my PC's can connect to the Hawking, BUT and this is the major problem - as soon as I enable these settings on the Hawking it causes my router to reboot repeatedly as if there's a conflict.
I can't see why. The IP addresses are different, both have access to each other MAC address wise, same subnet. Any ideas - please help!
Posted on Nov 16, 2008
I am
Posted on Aug 05, 2008
  • 56 Answers
Are you still having the problem?
Posted on May 30, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
The problem might be that you have good connection to the router but having connection trouble between your router and the internet.
Try accessing your router by typing your Gateway into the address field of the web browser of your choice.
Then click on WAN (Wide Area Network) and check your external IP Address. Beside it you will find a button that says "Renew".
The loss of connection might be the result of poor router configuration, bad cable connection or ISP (Internet Service Provider) connectivity trouble.
Posted on May 28, 2008
How do you change limited internet access to full access
Limited access usually means you have full access to your network through your hotspot, but the hotspot is not connected to the internet or it cannot get a signal.
Sep 25, 2012 | Dell Inspiron 1525 Laptop
Im trying to connect my wii to the internet at my new house and it won't it keeps saying unable to find access point. please confirm the ssid and try again?
I'll advise briefly, but suggest you find the router page address (something like 198.168.2.1). You can find this by looking in the manual for the router. You can also double click to open the router and then "open device webpage"
This will allow you to access the router settings and configure the wireless protocols and passwords / security. Without knowing which router you are using, I cannot give specific help.
You need to ensure that the wireless password that you set in the router is typed EXACTLY into the network connection on your PC / laptop
Jun 13, 2011 | Nintendo Wii Console
My wireless network connection status in connected speed is11.0 and my signal strength is good but I cannot connect to the internet
Are you running any Internet Security software such as Norton? Also make sure your wireless router is actually connected to the Internet, just because your laptop is connected to the router doesn't mean the router is connected to the internet.
If you can, plug your laptop in to the router via an ethernet cable to make sure Internet access is working, alternatively if you have another computer connected to the router check the internet access on that one.
Also try doing a soft reset on the router, just disconnect from the power for about 30 seconds, reconnect, wait one minute then try again.
Jun 26, 2010 | Computers & Internet
The computer says that I am connected but only "local" and cannot actually connect
That message usually means that a signal is very weak.
If your router is nearby (and not through many walls), there is a problem with your router and/or network signal.
Reset your router and if still a problem, contact your provider.
Hope this helps.
Sep 07, 2009 | D-Link AirPlus DI-524 Wireless Router
Created secure network see it using wireless on laptop key info
srry for the harrasment,u can do 1 thing..if u have a desktop computer connected directly to the router u can find the ip address of teh router and can go into the router setup page and change the security key,,or else u can connect an extra cable from ur laptop to the router and can enter the router page as well.
on ur desktop computer go to control panel-network connection-Local area connection,,if it says connected double click and u will find a box coming up with 2 tabs,,general and support,,click on support and find default gateway,,it shud typicall start with 192.168.x.x{depending on the class of ip address},then open up mozilla and type in the address at the top address bar.a small box with username and passwrd comes up.put"admin "in username and dnt put anything in passwrd field,,hit enter,,if the same box comes up then u had changed the passwrd during setup of the router{in tat case u have to call up the router manufacturer and do a hard reset of teh router and reconfigure the router to ISP settings}otherwise if u see a dlink window coming up,,that means u r in,,u search for wireless security and u will find the WEP key or the WPA key which is the network security key,,write it down exactly as it is as it is case sensitive
plz giv a good rating and best of luck
May 15, 2009 | D-Link AirPlus DI-524 Wireless Router
Have a wireless connection, says it's connected but no internet
Go into the properties of the connection and see what it says if there is an error or whatever.
Also when you find a signal it will be secure and you need a password to login.
Sometimes it connects but it will actually be limited to no connection.
You can also go to the
start button
then click on run
then type in that box
cmd
Hit the enter key.
Then type in the box that comes up
ipconfig
Hit enter
See if it comes up with a ip.
If not then type
ipconfig /renew
Then hit enter
If it does a hold and a ip don't come up that means it don't have a good connection and that's why you can't get on the net
Hope this helps
Happy Holidays
Dec 25, 2008 | Dell Latitude C640 Notebook
"Local Access Only"
You need to look on the back of your router and find the small reset button. Push it and everything should reconfigure. If not Go into your device manager and see if you can find something called a NIC card or Network Interface Card, or something called an Ethernet card, if those are not listed, it means your driver has been deleted somehow. You can go to the manufacturers website and download a new driver.
Sep 22, 2008 | Linksys WRT55AG Router
Not staying connected
i think you have problem in your LAN port try to buy a USB LAN card 100% im sure it will gonna work.
Mar 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
CGA5722 - Boxed in "A
can you a little bit describe what other device that you are using. maybe access point. Are you using an access point?, or switch?
Feb 15, 2008 | Computers & Internet
Hawking HWREG1 Repeater Logo
617 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
