Question about Garden
Mt tire in the front poped and I can not inflate it?
    President:
  • 1,033 Answers
Do you have a tube it the tire? if you don't, pull the wheel off and lay in flat on the ground, put pressure around the tire at the rim edge and begin to pump with a compressor. A regular hand pump is hardly sufficient. You may even try standing on the tire edge while pumping if you can't get enough of pressure with the hands. The point is to push the tire inward to prevent air bypassing while pumping.
Posted on Oct 03, 2010
I changed 1 of my valve sensor so i need to no how to reset the tpms light
By operating the tire pressure warning reset switch, the tire pressure warning ECU can be set to issue a warning at an inflation pressure that corresponds to the standard pressure of tires .Therefore, you must set the warning threshold to the proper value in order to comply with the local regulations .Operate the tire pressure warning reset switch only after the inflation pressures of all tires have been adjusted on the vehicle.To initialize the system, press and hold the tire pres- sure warning reset switch for 3 seconds or longer with the ignition switch in the ON position. When the system receives the
initialization signal, the warning light blinks 3 times (1 second on, 1 second off). During initialization, the tire pressure warning valve and transmitter measures the inflation pres sure of the tire, and registers the signals that are transmitted into the tire pressure warning ECU at a frequency of once per minute. The initialization process is completed when signals from all the tires have been received. It takes a few minutes .
Tire size Inflation Front Inflation Rear
P 195/65 R15 89S 30 psi 30 psi
195/65 R15 91H
P 205 /55 R16 89H 32 32 psi
P 215/45 R17 87W
205/55 R16 91V
Dec 10, 2013 | 2010 Toyota Corolla 2.0
CORRECT TIRE PRESSURE FOR REAR TIRE
From the Clymer
TIRE INFLATION PRESSURE (COLD)
Front 28 rear 32 add 4 for riding double(from the Clymer manual).
Tire inflation pressure for factory equipped tires. Aftermarket tires may require different inflation pressure.
Jul 03, 2012 | 1995 Suzuki VS 800 Intruder
I just had a yellow exclamation point surrounded by parentheses light up on the dashboard of my 2006 Honda Pilot (2wd) and on little car diagram the front left tire is illuminated? Is it a Speed sensor or...
Its the low tire light. On the drivers side door opening you should be able to find a sticker that tells you the proper tire inflation for you vehicle. Check all four tires to make sure they are properly inflated. If that tire is low it probably indicates there is a leak. Once all four tires are inflated drive the vehicle on the freeway for about ten minutes. the light should go out. If the light comes back on and the same tire is low than there is definitely a leak.
If all the tires are properly inflated and the light comes on there may be a problem with the sensor in that wheel. A TPMS scanner will be needed to see what the sensors are displaying for pressure.
Sep 07, 2011 | Honda Pilot Cars & Trucks
I need the correct tire pressure reading for 2003 VW beetle
check the inside of the drivers front door. there should be a sticker with the correct tier inflation for your beetle.
29psi in the front and 28psi in the rear should be pretty close.
Jun 10, 2011 | 2003 Volkswagen Beetle TDI
What is the recommended tire pressure for the 2001 V10 volvo wagon
I would open your drivers front door there should be a label inside on the door or the door jam stating what Volvo wants the front and rear tires inflated at follow the manufacturer label inside the door for proper tire inflation.....
Dec 08, 2010 | 2001 Volvo V70
2000 Expedition inflation pressure for oem tires?
look on the sidewall of the tire. will show max inflation press, and you should run about 5psi below that unless you have a heavy load. then run the max.
Jul 21, 2009 | 2000 Ford Expedition
Where can i get my back tires fixed?
These small ATV and MiniMoto style tires can sometimes be found at store like Harbor Freight or TSC (tractor supply center) if you have one anywhere nearby. If the tire has an inflatable inner-tube you can most likely repair it with rgular old bicycle repair patches.
May 04, 2009 | Razor MX500 Dirt Rocket
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
