Question about Gigabyte Slot 1 GA-6BXC Motherboard
Gigabyte Slot 1 GA-6BXC Start Up UnStable
When start up motherboard Gigabyte Slot 1 GA-6BXC, with CPU P2-400MMX, with jumper on mainboard :
JP10 : 2-3 (normal 100Mhz)
SW2 : Ratio-4
SW1 : CPU-100, AGP-66
SDRAM 128MB-PC100 (status new)
CDROM 52X-LG
HDD 10.2GB, SEAGATE-ATA (Setup windows 98, status nomal)
These Problem:
Memory test : < 128MB
IDE autodetect : Found HDD 10.2GB, Found CDROM in CMOS
system halt, or only boot DOS from CDROM but can not access HDD
after disconnect HDD and startup, boot DOS from CDROM ok
  • vd_khoa May 28, 2008
    when my computer occur this problem, i did setup HDD to another PC, HDD start up Windows98 OK, i checked this HDD by software Smart Partition,and Partition commander get information : mode -LBA, Bad sector not found, Partition : type - FAT32, Primary-DOS, Status Active
    i used another HDD(new) setup on computer have problem, but also
    Bios code :
    I AWARD
    All rights reserved
    PCI/PNP 686
    S/N220236506 -copyright 1998
    now startup FAN-CPU run, monitor can not display anything, LED HDD light a few second and then dark,
    reinstall SDRAM all slot DIMM empty, speaker PC alarm
    bios orginal dont have copy chip
Send me about all jumper on GA-6BXC and user manual version pdf
because i'm plug in PCI usb 2.0 ALI chipset M5273 and "system hang"please send me some solution about this problem...??
Email " didikratih20042003@gmail.com "
thank's
best regards
DIDIK
Posted on Jun 19, 2008
    Scholar:
  • 119 Answers
I recommend that you formatt your HDD to a FAT32 system probably by using another pc then you should also ensure that your bios is setup for the appropriate operating system. maybe just download the appropriate bios files off the gigabyte web site.
Posted on May 27, 2008
  • castatroy May 29, 2008
    It sounds like you have a CPU or a Motherboard problem. these are the only two things that causes your monitor to not display anything during startup first install the RAM and then replace the CPU and see if you power it up anything dispplays if nothing then the problem lies on the motherboard or graphics card if you have one installed
D33OO6 GIGABYTE DUALCORE CPU SOPORT
Hello seach for info here at gigabyte:
http://www.gigabyte.us/support-downloads/download-center.aspx
By entering the right mainboard model number.
The number is printed in on the mainboard by the pci socket.
Good luck
Dec 05, 2012 | Gigabyte GA-8I845GVM-RZ Motherboard
Ga8i915pmd motherboard jumper settings
Hello try to find the manual here at gigabyte:
http://www.gigabyte.com/support-downloads/download-center.aspx?kw=GA-8I915PM-D&ck=
By typing in the right mainboard number.
Your mainboard is an INTEL based card.
The jumper settings is basicaly the same to almost all mainboard
Jul 17, 2012 | Computers & Internet
Where does the vcc connect to on a ga-6bxc mainboard
Hello the manual and other files can be downloaded here:
http://www.gigabyte.com/products/product-page.aspx?pid=1445#manual
Select other files in download type.
Good luck
Apr 03, 2012 | Intel Motherboard
@hotmail.co.ukNeed the Jumper Settings for Gigabyte GA-5SMM Motherboard
I have provided a link for you to copy and paste into your web browser to go to the Gigabyte model GA-5SMM support page.
The page shows a list of manual downloads for your motherboard, click on 3rd download on the list from America, after opening and go to page 3-4 for jumper settings for your model mainboard.
I recommend printing pages you my need for future reference.
Good Luck
http://english.gigabyte.ru/products/page/mb/ga-5smm/download/manual
Sep 05, 2011 | Gigabyte GA-5SMM Motherboard
Preciso dos driver da placa m&#195;&#163;e gigabyte ga-6bxc todos os driver
please try www.motherboard.cz/mb/gigabyte/GA-6BXC.htm
best regards
b.m
Nov 19, 2010 | Gigabyte Slot 1 GA-6BXC Motherboard
I have GA-6BXC motherboard, came with a Pentium II 400 mhz, I upgreded it to a P3 550 mhz,lastest Bios F3 is loaded, ugraded the memory to Kingston ,from there website. No when I turn on the computer I get...
A couple questions:
1) I assume you have the manual. 6BXC Manual
2) Just double checking...the BLACK boxes marked in the manual for the switches are the white switch "levers" for lack of a better term. So switch 1 should have all 4 levers up. (Toward the CPU.) Switch 2 should have the left-most lever down and the other 3 up. Are those correct?
3) The RAM modules have a max of 256MB in each slot. Is that good? (Try with only one module at a time.)
4) Does JP10 have the jumper on pins 2 and 3? (Page 16)
5) Is the battery good?
If all that is good, clear the CMOS. See page 17. Take the jumper from pins 2 and 3 and place it on pins 1 and 2 for about 15 to 30 seconds. Then place it back on pins 2 and 3. Try to reboot.
Also, what kind of graphics card are you using?
Awaiting your response.
Wayne
Nov 25, 2009 | Gigabyte Slot 1 GA-6BXC Motherboard
Motherboard
try to remove and place to another slot your bios like the jumper near the battery and put it back again. see what happens next. see also if the wires from the switch of your cpu is correctly connected to the motherboard.
Sep 10, 2008 | Gigabyte GA-945GM-S2 Motherboard
Lan card
Use a different PCI slot and reinstall the drivers for your LAN card. If this does not fix the problem there may be a compatibility issue between the network card and some other software (eg. irq conflict etc.), or the LAn card may be slightly faulty and have problems on some motherboard.
In this case you can try troubleshooting the problem.
If you cannot find out the problem at a glance, checking in device properties, you may be forced to reinstall Windows. In this case I suggest to just replace the part. The Ethernet (LAN) pci card is quite an inexpensive part, and you can still use this one on a different computer.
Regards
Apr 02, 2008 | Gigabyte Slot 1 GA-6BXC Motherboard
Gigabyte Slot 1 GA-6BXC Motherboard Logo
500 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
