Question about Freezers
I need a fridge freezer with external measurements H164cmxW73cmxD56cm. H could go up to 170cm. I want max freezer space, so at least 50/50split
  • 316 Answers
You are going to have to do your own leg work on this one I think. Maybe somebody here can answer that question, however this is a repair forum and I can't memorize the dimensions of every possible fridge out there. My suggestion is to bring a tape measure with you to the appliance store of your choice, or look at online catalogs, they may actually list the dimensions you seek.
Posted on Oct 04, 2010
Looking for a replacement seal measures 1040mm x 600mm
probably the best idea is to contact a local fridge/ freezer person that replaces seals on the doors of fridges and freezers (yellow pages for a start-fridge repairers)
they have an assortment of seal profiles on board and they make the seal to suit the door on site
The cost is about 75% of new price
ask the service agent spares for a seal, because although the freezer may be old , seals didn't change all that much and you may still get a seal from them
From the size I am guessing that it is a chest freezer probably an electrolux/email product and you may be lucky if it is
Mar 31, 2016 | Freezers
Why is the pilot light on my ERN7926 frost free flashing?
To Start the Appliance
Allow the appliance to stand for 2 hours after
installation. Plug in the appliance and switch on at the mains
supply. Turn the thermostat control (B) to a midway
setting and adjust the slider control, situated on the
back wall of the fridge section, to a midway position
between "MIN" and "MAX".
The pilot light (A) will illuminate. Leave the appliance for approximately 4 hours for the correct temperature to be reached before placing food inside.
To switch off the appliance turn the thermostat
control to position "?"
After 4 hours, measure the temperature in the refrigerator and freezer. Should be between 2 and 10 degrees centigrade in refrigerator and app. -18 in freezer.
Dado
Sep 07, 2014 | Electrolux Freezers
Freezer & fridge not cold enough
Please check the Thermostat switch settings. Try to put it to max cool and then see the results. If it still does not cool the you have to check the refrigent. It is lee and leaking somewhere. Get a technician and get it charged up.
May 18, 2011 | Freezers
Not freezing
Either the defrost circuit has failed or the refrigerant is low - my money is on the defrost circuit.
Most defrost circuits have three main parts:
1) defrost electric heating coil
2) defrost terminator
3) defrost timer.
The heating coil and terminator are in the freezer compartment - behind a protective panel. The heater is usually piggy-backed on the freezer coil and the terminator is in contact with the freezer coil to detect its temperature. The defrost timer is a simple assembly of a clock motor with switch contacts that can be located anywhere the manufacturer desires. The timer turns on or enables the defrost circuit every 8 or so hours for up to 30 minutes give or take.
When the timer has enabled the defrost cycle, the cooling mode ceases; the compressor shuts off and power is sent through the terminator to the heater. The heater warms and melts any ice build up on the freezer coil. The water drips to a pan and flows down the tube to a pan under the fridge - where it is evaporated off. The heater warms the freezer coil until either a) the timer returns to cooling mode or b) the terminator senses a preset rising temperature on the freezer coil. Once either condition is present, power is interupted and heating stops. The compressor is energized through the adjustable thermostat in your fridge. Since it is warm, the compressor turns on and cooling begins.
If any of the components listed above (1,2 or 3) have failed, the defrost cycle never warms the freezer coil and the ice never melts to clear the freezer coil as intended. Air can not be circulated through the freezer coil since it is choked with ice, so even though the compressor runs, the fridge and freezer spaces never get colder. The adjustable thermostat never sees the temperature you've set so the compressor never shuts off.
Water dripping in the fridge is melting ice from the freezer space - as the freezer is not getting colder - only the protected space around the freezer coil is.
To fix this, you'll have to get the service manual or schematics for the fridge to determine where the parts are located and do some troubleshooting with a multimeter after disassembling the freezer compartment and wherever else to access the timer if needed. This is not a good first appliance repair job for a DIYer due to the danger of refrigerant and testing live electrical parts in closed in spaces.
I hope this helps.
May 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
Fridge Freezer making annoying noise
What kind of a sound is it making???
May 03, 2008 | Hoover Freezers
External Surfaces of Fridge/Freezer are hot
That is normal, refrigerators work by removing the heat from the storage area, thus making it cold. This heat has to go somewhere. Most of it is blown out the back but some escapes through the sides of the fridge.
Dec 28, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
55 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
