Question about Marantz Audio Players & Recorders
I have a marantz integrated stereo amplifier PM-57 and it keep cutting out regularly. its sounds like a relay is clicking in and out. what can i do?
  • 682 Answers
Please disconnect loudspeaker one by one until the problem is goen -and fix the bad one by change the cabel first and the speaker second if all above does not solve the problem send your amp to service center to repair.
Posted on May 28, 2008
Marantz problems
The speakers are 8ohms. Always try using speakers 6 or 4ohms. For B&W 683 on PM 6004 is too low. You should go for PM 7000 or 8000 series to catchup with 683. Also when you increase the volume please decrease the bass as well.
You need 8ohm 55w to 90w or 4ohm 80w to 110w speakers.
Jul 20, 2014 | Marantz PM6004 Integrated Amplifier
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
Hi, I have a Marantz PM 57 Amplifier that is not working. The power light comes on but no sound from speakers (nor headphones). Just moved house, and hadn't used it for a while (don't remember it not...
After a move and something doesn't work that could have before, it's always best to check inside for signs of damage. It might just be a bad soldering joint, so it could be just a small amount of damage.
Jan 14, 2011 | Cambridge Audio Azur 340A 2-Channel...
The fuse keeps blowing in my marantz pm-57 amplifier. It says it takes a T 2.5A 250V fuse. I can only find 2.5A 250V fuses. What relevance is the ''T''.
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Jul 31, 2009 | Marantz PM-15S1 2-Channel Amplifier
PM-68 Marantz Receiver keeps shutting off sound after a few
try turning the system on with no speakers hooked up. and see if it clicks off. if it does,the problem may be the a short on the speaker connections.
Dec 24, 2008 | Marantz PM-68 Amplifier
Can I remotely control speaker outputs on the Marantz PM 8003?
HI...
You need an 8 ohm stereo "L-pad"
Try partsexpress.com
or
mcmelectronics.com
Dec 21, 2008 | Marantz Audio Players & Recorders
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
Vintage Stereo Connection ???
Hi spanky
Where to start :) I am excited thinking about them :p You got 2 totally cool pieces of classic vintage gear there in the C2 and the Marantz. I have a C2 preamp myself (gathering dust but wont sell it cos its excellent) and the marantz would be totally cool to have(but then I am a little biased towards 70's vintage marantz). They ruled the roost in HiFi amps throughout that decade.
Because they are both integrated amps, you could use them as standalone systems with a pair of speakers, and just plug your favourite gear into them. If you just wanted to run up a nice sounding HiFi, I would sell the kenwood gear and just keep the Marantz. The Kenwood kr1100 has the edge in power, so if it is grunt you are looking for use that. Because vintage sound is all about stereo, you only really need an integrated amp to get great results.
the specs are
# Kenwood Model Eleven G (KR-11000G) Receiver
120W per channel min RMS, both channels driven, at 8 ohms from 20 to 20.000 Hz with no more than 0.03% total harmonic distortion.
Dynamic power output 440W at 4 ohms
Power bandwidth 5 Hz to 70.000 HZ
Frequency response 5 Hz to 100.000 HZ -1.5dB
Signal to noise ratio 115dB
The marantz is a little lower in power at 75rms a channel, but will have the sonic edge in vintage sound over the kr1100. Look them up on ebay and you will find that they do have some value to collectors and people seeking nice tone. There is an 1152 for sale here for AU$900
Best bet is to fire up the 2 integrated amps,and see how they are going. Run them for several hours to be sure there is no strange noises and crackles. Then decide if you want power or finesse.
You could also run both amps from the C2 preamp by connecting to the Amp in connections to the rear of the integrated amps.
happy to talk to you more about it, hit me with a Fixya if my advice was helpful to you. I would keep the marantz, use that and sell the rest and buy some nice speakers:)
regards
robotek
Jul 20, 2008 | Audio Players & Recorders
My Marantz PM-45 integrated amplifier will occasionally cut out by switching off a relay.
Hi HouseofBlues
The problem you are facing is the speaker protection is turning on to prevent the amplifier from damaging your speakers. It will need some service work done to it to prevent it from happening. I suggest you get it attended to sooner than later, as the problem will be caused by dry solder joints that will need to resoldered, or a semicinductor that is failing. If you are a gun with a soldering iron, you could do this yourself. Check about parts of the amp that runs hot, particularly transistors and resistors in the output stages. resolder all output transistors, and any parts that are mounted to a heatsink. Also focus on areas of the PCB that has discoloured. This is often where the problems occur.
I am more than happy to answer any other questions you may have about it, just give me a hoy :)
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 01, 2008 | Marantz Audio Players & Recorders
432 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
