Question about Campbell Hausfeld 1800 PSI Electric Pressure Washer
When hooked up, (electric+water) unit will not activate. Power wanr is squirting water but motor is not on.
  • 92 Answers
Dear Sir,
This is a problem like the ones I explained. I will write again the explanation.
Dear Sir, What happened is that you have a control valve (Spill Valve)..that when pressure is created it will closes down and puts off electricity by hitting a micro switch. This happens if one leaves a lot of soap in the system or more often the machine is stored under pressure. Never store a power washer under pressure!! Now all one has to do is locate the spill valve ...lubricate or change with a new one. Always lubricate with silicon grease. Also never put on a power washer on without water being fed.
The spill valve is usually located where you see 2 wires coming out on the machine inside.
Well just a small reminder.....if you left the machine stored with pressure...most probably you have the spill valve jamed in the closed position, thus cutting electricity off.
Regards, Fulltech
Posted on Apr 20, 2011
  • Martin Grech Apr 24, 2011
    Please note that I am not responsible, for any misuse, misinterpretation, damage caused to inexperience work, incompetent workmanship and damage or harm caused by irresponsible use of this advice. This is just advice and cannot be held responsible for work being done when myself I am not present.
    Fullteh.
How do I make ventilate message go away
  • Check to make sure there's nothing inside your flow meter.
  • Check the flow meter wire connection at the board (cpu/pcb).
Jun 22, 2015 | Saeco INCANTO DELUXE Espresso Machine
Wipers not squirting water
Check for the most obvious causes first- Broken or disconnected hose leading to the nozzles? Are the nozzles themselves plugged? Is the fuse to the electric motor which drives the pump ok? Is the pump itself running when you activate the switch for the washers? Check all these before escalating into spending more money.
Good Luck!
Jun 26, 2012 | 2007 Volkswagen Jetta 2.5 Sedan
Maytag LAT9635AAE won't start wash cycles
you can try to check the water level sensor Assembly this unit controls the fact that your washing machine will not wash until the proper water level is reached, this unit has a rubber hose attached to it and a wiring plug or connector for the electrical power to activate the motor.
Jan 10, 2012 | Maytag Washing Machines
I have an AE125 - had it for a couple of years at the cottage. We got the water hooked up this spring and all was fine. Last weekend, the unit stopped working. I flipped the breakers a couple of times...
Can tankless electric water heater be repaired? Sure.
Is it worth the expense if problem is going to happen again? I can't answer, but can offer resources.
New tank-type electric water heater costs $207 and new tank-type gas costs $320 at local box store.
You can install new tank-type electric yourself in a couple hours. DIY repair on tankless is not easy since parts are not at local box store, and what part do you need, and tankless parts can easily cost more than new tank-type water heater.
Open following link for Bosch troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
GENERALLY, Tankless require .4 gpm (gallons per minute) water flow to activate heating cycle, and then require .25 gmp flow to keep heating cycle going.
For example .4 gallon per minute means faucet can fill 1 gallon container in 2-1/2 minutes
Some tankless units require more water flow, for example .75 gpm
Tankless water heaters have flow sensor that tells computer chip when enough water is flowing to activate heating cycle.
If the sensor is clogged, or if water filter inside tankless unit become clogged with dirt or sediment from hard water, then the unit does not signal enough water flow and will not activate.
Home filtration system and water softener can also slow the flow of water.
Low water pressure and crossover problem on single-handled faucet and crossover on recirculation system check valve and high thermostat setting can also cause heat cycle to not activate.
Tankless cannot be exposed to water with more than 11 grains hardness or parts inside tankless will coat with sediment and not work. Within 2 years the unit will not work, with diminished efficiency from the beginning.
http://waterheatertimer.org/Battelle_Final_Report.pdf
If water is hard, and you cannot soften the water, or if water is dirty and cannot be cleaned, then the best recommendation is to use tank-type heater instead of tankless.
All costs are energy. For average home: Tankless electric is NOT cheaper to operate than tank-type electric. Tankless gas saves $1-8 per month. However, cost of unit and installation, cost of potential repairs and cost of parts, difficulty of DIY repairs, required yearly-monthly maintenance, etc outweigh expected savings.
http://www.pmengineer.com/Articles/Cover_Story/8cf9e86f7c298010VgnVCM100000f932a8c0____
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 31, 2011 | Bosch AE125 PowerStar 4 GPM Indoor...
When i switch my karcher on the motor makes o noise and does not turn
This sounds like you may need a new capacitor. It is not a costly part to get. What the capacitor does is "jump starts" the motor so if it broken the motor will not start.
A test you can do is if you take off the front caseand then set the machine up as if you were going to use it. then when you turn on the machine quickly push the fan blade of the motor with a flat headed screw driver. If this makes the machine start to work, then you know that you need a new capacitor.
Just be carefull when doing the test.
Please remember to thumbs up :)
Apr 03, 2011 | Karcher K2.26 Electric Power Washer
Not making ice cubes
Fill ice maker with tap water and let freeze. If ice dumps and water does not refill tray then the water control valve is defective. If ice remains in ice maker then ice maker is the problem.
I think Amana still uses the Whirlpool made ice maker. It consits of a mold, a paddel to remove the ice, a motor to drive the paddel and a cam. The electrical part consists of mold, thermostate or sensor ( use to be thermo-disc), micro switches, 1 to hold the unit running 2nd to alow water to flow at a certain time and a mold heater. Sequence of operation: Thermostate senses mold is cold, activates motor to turn paddels and cam. As cam turns it depresses a micro switch to hold motor running. Motor cam and paddel turn, mold heater is also turned on. As mold warms the paddels scoup out the ice. Contunes to turn until a spot on the cam activates another micro switch to allow water in. Motor continues, as cam reaches a spot it releases the micro switch for water andthen the switch holding the motor on and unit shuts off ready to do it again.
Sep 09, 2010 | Amana ARB2257C Bottom Freezer Refrigerator
I have an ASKO D3251 that is not draining. We
You will need to remove the bottom panel of the unit below the door that exposess the motor and the electrical along with water hook up. Now you will nee to manually go through the cylces (or let the machine cycle) to rinse. Once in the rinse cycle you should have heard the selinoid activate to drain the water. This selinoid click and pulls an arm down when in drain mode if you are looking under the unit you will either hear it or see this activate. If not then the selinoid is out, if you hear it activat then you need to look at the back of the motor to see if the motor itself is turning. You should be able to see the fins on the back of the motor turn once it goes into drain cycle. If you do not see the motor fins turning (you have to look through the vent slots located on the back of the motor) you acan take a small slotted head screwdriver and with the power off, you can insert this screwdriver into the vent holes in the back of the motor to spin (or move) the motor fins. If they do not move freely then the motor itself is froze up in that case a new one is needed. If the spin then try your drain cycle again since you may have unfroze the drain motor.
Good luck hope this helped
Dave
Feb 02, 2010 | Asko D3251HDSS Stainless Steel Built-in...
The water thing of the windshields is not working, I already tried putting a pin through the hole to see if it was clogged, and I checked the water thing at the front and its full. What else can I do?
have someone hold down the washer stalk to activate and listen, if its not spinning to squirt water then you may need a new pump, or the switch on the column.
Jul 16, 2009 | 2002 Kia Rio
Instant hot water dispenser does not heat water.
I had the exact same problem. I even replaced the first unit with a second unit...because I was sure I hooked everything up correctly. Then I called their support line and and felt very stupid. They asked one question "are you plugging in the Quick&Hot into the same electrical outlet as the garbage disposal"?. I said yes..and the garbage disposal works fine (thinking that this indicates a good electrical outlet). She then said "That outlet works off of a switch so no electricity is getting to the Quick&Hot until the disposal is turned on). Gosh darn it...that made total sense. I then tested this out by plugging an extension cord into a different outlet and it worked fine. Boy...do I feel stupid. Hope this helps.
Jan 17, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
Oct 11, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Campbell Hausfeld 1800 PSI Electric Pressure Washer Logo
171 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
