Question about Husqvarna Viking 1
I tried to remove the bobbin case (viking 500) and couldn't figure it out. I had to clean lint build up. I got the lint out(took forever with the bobbin case in the way)...now the bobbin case is jammed and I can't move it at all. Do I have to take it in (to the dealer) or is there an easy way to take out and put back in correctly.
SOURCE: Husqvarna Viking #1plus bobbin problem
I have changed stabalizers and the type of bobbin thread i am using (invisible poly) and it seemd to have solved the problem. Note: wind invisible thread very slowly and carefully it is like fishing line
Posted on Dec 16, 2008
SOURCE: Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
Posted on May 28, 2009
  • 76 Answers
SOURCE: Husqvarna Viking C-10. Bobbin Case broke, dealer
check this site out, I find a lot of good stuff on it
www.cutsewservice.com
Posted on Aug 28, 2009
  • 371 Answers
SOURCE: The stitch bunches on the bobbin side. The Viking
Parts are still available. Make sure you are using an authorized Husqvarna Viking dealer. Check the Husqvarna Viking website for dealers in your area - http://www.husqvarnaviking.com/us If the dealer is unable to fix or get parts, have them send the machine to Husqvarna Viking Service Technician headquarters in Tennessee. They can repair or rebuild parts no longer available. Also parts may be available from third party = http://www.pd60.net. Good luck.
Posted on Sep 25, 2009
  • 152 Answers
SOURCE: freesia 415 - bobbin thread is jamming up will
1. Put in a new needle
2. Take the thread off the top of your machine and rethread the top. Make sure the presser foot is in the up positon when you thread your machine because that is when the tensions discs separate so your thread gets deep into the unit where it belongs. The tension dial (the small dial) should be on 4 or 5.
3. Inspect the bobbin area. Do you see the thread laying across the bobbin itself? You should alway see the thread laying across the bobbin in that model. That tells you that you've threaded the bobbin case correctly. The thread must be pulled into the metal guide of the bobbin case, from approximately the 6 O'clock postion to the 7 O'clock position.
4Never turn the handwheel away from you with the 415. You'll notice that the take up lever is of a more open design. If you turn the handwheel backwards (away from you) the thread will jump out of the lever and jamming will result.
Posted on Oct 12, 2009
My viking emerald 118 machine just started breaking needles and the bobbin thread will not hold. YOu can pull the bobbin stitch out by pulling the thread.
Check the upper tension by lowering the presser foot and pulling on the thread through the needle. You should feel resistance. If not, take a stiff brush and clean out the tension disks/dials removing any loose threads or lint. If upper tension is ok, check bobbin tension by pulling thread through needle plate opening. You should feel resistance. If not, remove bobbin case and brush any loose threads or lint from the case, especially in the tension spring where the thread is snapped into place. You may need to use a sharp needle to dig in between the spring but be careful that you don't damage it.
Jun 17, 2014 | Husqvarna Viking Emerald 116 Sewing...
Birds nests embroidering husqvarna viking designer se
it would be a good idea to have the machine serviced
Try these suggestions for bird nesting
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Feb 19, 2014 | Sewing Machines
Trying to clean under the bobbin case on Viking Emerald 183 and I can't get it out.
When looking at your bobbin case from the top you will notice the hook. Think of the tip of the hook as a clock dial. At 12:00 the hook would be behind the needle. Turn the hand-wheel is at 10:00 this will allow more clearance when removing the bobbin case/basket.
Jan 19, 2014 | Husqvarna Viking 1
Needle only moves a little and then beeps saying needle up when the peddle is pushed. Machine will not run.
Good day Po!!!
Sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble; >Do this;
1.Top tension to tight >loosen tension 1 turn
2.Machine improperly threaded >check threading
3.Thread twisted on guide post > "
4.Thread twisted out of tension > "
5.Take up spring bent or broken >Check action of spring
6.Thread jumped off pull off finger >Check threading
7.Needle bent or burred >new needle
8.Bad cone of thread >try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tension spring to tight >Loosen tension slightly
2.Bobbin threaded wrong >check threading
3.Bobbin wound to tight or uneven >try new bobbin
4.lint or thread on bobbin case >clean inside case
5.Lint or thread inside hook >clean inside hook
6.Bobbin case nicked bent or burred >check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred >change
2.Needle set in crooked >Check
3.Thread jumped off take up spring >check threading
4.Thread jumped off pull off finger >check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth >Tighten bobbin tension
or loosen top tension.
2.forming loops on bottom of cloth >Tighten top tension
3.Bobbin placed in case incorrectly >remove and replace
4.Bobbin thread slipped from under >check threading of
tension >bobbin case
5.Lint or thread in top tension >clean between tension discs
Please just add a comment if you did not solve your problem by doing these procedures.
If this solution helps you please do not forget to testify and rate me...Thank you so much for using fixya!!
Jul 08, 2011 | Husqvarna Viking 1
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Just want a maintenance manual so I can oil my Elna 740 Excellence sewing machine. Emailed the company, but they tell me just to have it done with service visit once a year. I want to oil the machine...
The manual should show you how to clean out the rotary hook area by brushing it out with a little brush provided in your tool kit. It should also show you how to remove the bobbin case and clean under it. Important: if you haven't removed the bobbin case before, then please take photos beforre you start so you can get it back into the right position when you have cleaned underneath. There may be two red marks on the case and surround to match up but I couldn't actually get a close up image of this model to check this.
Here is image from my Janome 6500 manual for this procedure, it should be similar on your Elna 740.
There is probably also an oiling wick in the centre of rotary hook under the bobbin holder. Remove the needle plate, pressure foot and needle, then take out the bobbin and bobbin holder and underneath is a circular metal part with a hole/depression in the centre. Wick will be inside there, don't mess with it!!. Just brush the whole area out, removing the lint from the brush into your bin. Don't try to blow the lint out with compressed air either.
You can add a drop of good quality clear sewing machine oil to the wick every couple of months or so, but keeping the area clean is equally a good preventative measure.
May 09, 2011 | Elna Sewing Machines
Thread breaks and skips stitches
Open the needle plate, remove the bobbin and bobbin case.....refer to your manual.
Clean away lint and threads.
Thread with the presser foot up.
If this continues, take the machine and samples of the mis-stitching in for service. It could be the timing needs to be adjusted by a professional.
Feb 20, 2010 | Husqvarna Viking 1
Thread balls up underneath my feed dog when straight sewing. Why?????
Could be needle/hook timing. With machine off do the following to check timing -
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area and thread cutter area, removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew without thread balling up, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 24, 2009 | Husqvarna Designer I
Mar 21, 2009 | Husqvarna Viking 1
Can't bring up the bobbin thread
Sounds like hook/needle timing is off. Check it by doing the following with the power off:
remove bobbin, bobbin case, and needle plate.
If not timing, clean bobbin area removing lint and thread.
Make sure using only Husqvarna Viking bobbins.
Make sure the bobbin is unwinding in the correct direction.
If you are still unable to sew, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 27, 2008 | New Home HF-2022
Sewing Machines Logo
203 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
