Question about Seagate Barracuda ATA IV (ST340016A) 40 GB Hard Drive
Spin but not detecting - Seagate Barracuda ATA IV (ST340016A) 40 GB Hard Drive
  • Seagate Master
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Oct 03, 2010
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
Spin not working on final cycle
drainage blocked {water is detected as taking too long to drain so motor wont spin}
or brushes on the drive motor are worn {will adgitate but not spin as error is detected or just not a good contact}
they are easily replaced out for new ones
pretty much it
Dec 19, 2014 | Washing Machines
Wdbaaa5000asl
The PC will not detect a drive that is not spinning. Make sure the power plug is seated properly.
Jan 11, 2014 | Western Digital My Passport Essential...
Whirlpool washer dryer not spinning one item
In fact there are sensors that can detect higher vibration and there by control the speed. It must be seen if this is available on your model. Please check the capacitor to the motor, couple a similar one and see if the speed improves. Also check for free movement with your hand , if not you need to reset the drive assembly.
finally check on the motor, check the drive.
Jan 20, 2013 | Washing Machines
Hard disk not detected
Check to see if hard drive is fully plugged in/reseat cables/harddrive. see if this fixes the problem
if not listen to see if the drive spins up, if it fails to spin up then the hard drive is bad
if hard drive spins up but clicks at regular intervals, it is bad
Try a different drive cable
Try to replace with a known good hard drive, if it still is not detected check the bios to see if the drive controller is enabled.
If the controller is enabled and cannot detect a hard drive the controller may have failed.
Apr 06, 2011 | IBM X236 Server
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
The hdd does spin but is not detected
it is phyisically damage and will not work it is bettre just replace the hard dirve.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
May 10, 2010 | Western Digital Caviar WD800BB 80 GB Hard...
I have a KENMORE WASHER MODEL 11020894990.The slow spin comes on and works fine but when it stops to begin the faster spin it makes a klunk klunk noise and will not spin.
Well the klunk-klunk is the Break grabbing, to stop it, as it is detecting, what it thinks, is some sort of Unbalance or Overload, or detecting a motor fault, etc, real or not, and is shutting itself down because of this.
Feb 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Will not spin in any cycle does everything else but spin.
please check the lid switch, it won't spin if it detects that the door is open. could be a broken lid switch.
tnx 4 using fixya,
drcool
Oct 27, 2008 | Washing Machines
Seagate Barracuda ATA IV (ST340016A) 40 GB Hard Drive Logo
111 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
