Question about Epson Stylus CX5800F All-In-One InkJet Printer
Does this printer have a fuse? I believe it was surged through the phone line and the fax has not worked. Also the ink seems to dry out when not used regularly. Last when I plug it it sound like it is working but then the lcd screen fades and it will not do anything. I paid over 250 for this and gave up on it when the surge hit. I just dug it out and thought I would see if I could get it going.
J PENGUIN
  • 12 Answers
SOURCE: Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Posted on Dec 31, 2007
  • 43 Answers
SOURCE: New printer clogged
do the cleaning cycle>go to printers and faxes right click on CX4800 go to printing preferences go to utility/maintainance and head cleaning do it 3 times
Posted on Feb 02, 2008
  • 97 Answers
SOURCE: no ink = useless machine???
I used to have one of these printers and it should work fine without any ink. You might wanna try and put in a cartridge though but not necessarily a new one. All of the other functions of the printer should work just fine. On the question of needing a special software, the answer is yes. You can download the drivers and software that is needed from the EPSON website or just simply click on this LINK.
Posted on Sep 17, 2008
soumya176
  • 55 Answers
SOURCE: changed the ink cartridges and the printer will
directly is not change it will change the cartridge you go to printer service setting
Posted on Nov 16, 2009
  • 526 Answers
SOURCE: Able to send faxes but unable to receive.
you need to check how the fax machine is setup for receiving faxes. i recommend you try it first without the answering machine, to see if it works. if it doesnt, then it has to do with the auto answer or the number of rings not set right, if it does work, it could be that you need to set it to check for fax while the answering machine is answering, check the manual under answering faxes.
thanks adi
Posted on Dec 11, 2009
We have a DCP 165C printer but the black ink is not working the ink man who sees it says that there's a dry ink blocking what can we do about it ?
Hi, if you have a ink cartridge take a tissue with a little alcoh and clean the chip off, the ink has dryed up from lack of use
Jul 01, 2012 | Brother MFC J6510DW - Multifunction fax /...
Cannot receive faxes
The storm has likely damaged the phone line, or the ADSL microfilter (if you have one). Which is why it thinks a phone on the fax line is off the hook. Check your line for breaks and your ADSL filters for a blown filter.
Sep 18, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
I am having trouble with the printer. The DR is working fine. It sounds like it is printing, however it does not. print. There seems not to be a problem with ink The printer is not printing. I...
Definitely you have a problem with the printer.
That will not prevent you from sending faxes out, but did you try to make a copy?
If the machine sat idle for some time, the ink in the jets would have dried, but this will not generate any error messages.
There are cleaning kits available, and they usually work.
May 31, 2011 | HP 1040 Plain Paper Inkjet Fax
I have a HP Laserjet 3015 fax machine connected to a phone line but not a computer. When I send a fax or make a copy a dark vertical line appears on each page. Incoming faxes print with no line. I have...
The fax scanning unit/encoder is dirty.
The fax scanning unit is like a camera. It take a picture of the document.
The glass plate is dirty and you may purchase a FAX CLEANING SHEET.
Officedepot
http://www.officedepot.com/a/products/470251/Office-Depot-Laser-Printer-Cleaning-Sheets/
or similar product to clean out the dirty area.
The dark strip is cause by semi-dry wipe out correction ink.
Give your unit a good cleaning and let me know.
Jul 08, 2010 | HP LaserJet 3015 All-In-One Printer
INK SYSTEM FAILURE HP8250 I am using genuine HP 02 series print cartridges so ink is likely not the issue HP tech support has been horrible This printer seems to have a complex ink pathway. It uses a...
Yes, the problem is either air or dry ink in the ink feed tubes. Go to our web site at: www.ccl-la.com Look on the printer repair page and click the HP link. We have a step by step guide to purging the ink feed tubes that should get you back going again. Use the guide for Non-fax function HP printers. If the ink is dry you may have to repeat the purge several times to get the lines clear enough to print. You will also need to have full ink cartridges when you do the reset. If you have any questions just use the email address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 16, 2009 | HP Photosmart 8250 InkJet Printer
My fax dont work at home phone line
It may be an issue with the phone line OR the fax machine had a surge problem.
Oct 30, 2009 | Brother Multi-Function Center MFC-240C...
Can't send a fax
Perform the following before attempting more in-depth troubleshooting:
  • Is the fax set up correctly?
  • What type of telephone line is in use?
  • Is a telephone-line splitter in use?
  • Is a surge-protection device in use?
  • Is a telephone company voice-messaging service in use?
  • Is an answering machine in use?
Jun 17, 2009 | HP LaserJet 2840 Printer
Canon LaserCLASS Fax 710
replace the line going into the jack, also try unpluging the power cord and plug it back in.
Feb 04, 2008 | Canon LaserCLASS Fax 710 Printer
Fax Line Jamming - Cannot even use household phones
A power surge has come through the phone line, fusing the tiny relay in the modem/fax part of the printer. this is very common. I have also seen where you need to use the HP provided filter/splitter on the phone line to have the fax work correctly.
Sep 12, 2007 | HP Officejet 7210 All-In-One InkJet...
Epson Stylus CX5800F All-In-One InkJet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
