Question about Craftsman 22" Gas Hedge Trimmer
What premix ratio does trimmer 358-795330 use?
    Scholar:
  • 150 Answers
50:1 Don't use outboard motor mix
Posted on Oct 03, 2010
I have a 1998 Yamaha GP 760 waverunner. 2 stroke engine. It's been sitting all winter. Not kicking over when I start. I read to use a premix instead of starter fluid, but what is the premix ratio?
Mary, you have to give a lot more information as to make , model , year, 2 or 4 stroke,capacity before anyone can answer this
modern 2 stroke engines use a metering pump for the correct oil/fuel ratio and it is not premix
and what is wrong that you need starter fluid in the first place
post again with all the information and some one will be able to help
Mar 13, 2016 | Motorcycles
How do you check engine oil level on ryobi 2 strike line trimmer rpt-3000
Small two stroke engines don't have oil in the engine that you can check like a car engine has. The oil is a special "two stroke engine oil", that is mixed with the fuel in a preset ratio. Like 50:1 or a ratio similar depending on the manufacturer of the equipment. You would typically premix a certain amount of the oil with gasoline in a can as directed on the label.
Sep 21, 2014 | Garden
Ryobi instruction manuals
one small bottle of premix oil to one gallon of gas
Aug 01, 2014 | Ryobi Garden
Oil leak at the back
do you have an automatic oiler, or do you need to premix your fuel? if it is an automatic oiler, and I assume it is since that is the only oil involved in any trimmer I have ever owned, then I would say you have lost your supply line for the two stroke mix, this can be easly solved in a couple of ways, empty out the reservoir, and start to premix your fuel 40:1 would be fine, or you can fined the oil line and reatach it,
Apr 08, 2014 | Garden
Oil to fuel ratio
Many of the 2 cycle motors use a 40:1 gas to oil mix. There should be a label on the motor that tells what the mixture should be. You also can buy a premixed container that has the gas ad oil mix all in one can. Just pour it in the gas tank, then pull the starter cord.
Mar 17, 2014 | Garden
Gas oil mixture
use a good quality 2 cycle oil at 50:1 thats about 2.6 ounces of oil per gallon if you are using Red Armour or most other high quality oils. I have ran everything that calls for 40:1 at the 50:1 ratio with NO failures using Opti 2 premix.... all modern hand held equipment is usually 50:1
Dec 22, 2013 | Ryobi 26CC, 22 In. Hedge Trimmer
I have a sears 2 cycle mini tiller that worked great for the first hour but now won't start.
Do not use pre-mix fuel. Clean carburetor. Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil) .Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
check age of gas. Cannot be more than 30 days old.
Oct 10, 2012 | Craftsman Gas Mini - Tiller/Edger
How much oil to I add to the gas before putting it in my craftsman convertible?
Older units use a 40:1 mix while very new units use a 50:1 mix. I don''t know the age or model you have. Using 40:1 will NOT hurt a 50:1 machine. Here is a mix chart. Just 1/2 the stated ratios for a 1/2 gallon premix. 40:1 is 3.2 ounces/gallon of gas. Use half of that to make a half-gallon.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
Sep 05, 2011 | Craftsman Convertible 25cc. Gas Line...
Please tell me exactly how I mix the gas and oil for my 22 in gas hedge trimmer Ryobi Model RY39500A HT 26. What type of gas, what type of oil. Also can I buy this premixed?
If you go to your local home center in the lawn care section they will have these little plastic bottle of two cycle engine oil they treat a gallon of gas if this is your only machine that mixes gas and oil you probably will not use a whole gallon in a season and you should not keep the mixture for to long it will not last. So doing some simple math and looking at back of container try to mix the ratio down if a whole gallon is not needed. Good Luck...
Sep 05, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
What is the ratio for mixing gas/oil for a 2001 yamaha vino scooter?
Hi, Bonnies460 for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Premix or oil pump for an 04 yamaha vino 50cc
Premix And 2 Stroke Fuel Ratios For Your Dirt Bike
Yamaha YJ125S Service Manual
OEM parts for Yamaha
Yamaha YJ125T Owner Manual
Jul 17, 2011 | Yamaha Vino 125 Motorcycles
Craftsman 22" Gas Hedge Trimmer Logo
99 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
