Question about Tilia FoodSaver V2240
My food saver by tilia us patent re 34929 not sealing, light is not coming
5 Suggested Answers
  • 88 Answers
SOURCE: My Tilia Foodsaver 370 won't turn on. A light
you have to press hard to make it close than it should work
Posted on Aug 22, 2009
SOURCE: Tilia Food Saver Vac 420 sucks air but won't switch to seal mode
Thanks to Mikeytheeye!!!
I became frustrated and figured I had nothing to lose. I had no idea what a vacuum switch was, but I took it step by step and moved on. It happens to be the round brown piece that has the tube coming in on the board.You have to remove the six small screws to the board and flip it. I tried to remove the "star" screw without removing the switch from the board, couldn't do it (also, I only had a t25 star screw attachment that worked at first, but started to strip). You can turn the switch but it does not open. I waited until the morning to make a home depot run and got a t27 star attachment and a soldering kit (only $18). From there, you just touch the two points and the switch comes off. I also got the contact cleaner ($3) and let soak. After cleaning it out and letting it dry I put everything back together and nothing happened. I took everything apart again and I tightened the star screw down almost all the way. Put everything back together and presto - the sealer worked after the vacuum cycle. For the record, we have a Foodsaver v345 model. Thank you for all the help.
Posted on Jan 02, 2010
SOURCE: Food Saver quit working.
i have a game saver plus. when i start the seal light comes on then it sucks the door closed then the seal light comes on again and the door opens and it stops
Posted on Apr 30, 2010
SOURCE: We have a Tilia Profesional II. The unit just
I have the same problem, did you find a fix?
Posted on Jun 28, 2010
The progress light on the food saver is flashing red
The heater bar is too hot. Allow it to cool for a while before resuming sealing.
Oct 15, 2014 | FoodSaver Tilia 801 Food Saver Vacuum...
My food saver V3880 will not seal or vacuum. It was working fine and then just get working. Please help.
The problem must be simple. Bad cord? Bad switch at the hinge? It can be dismantled and tested for continuity with a multimeter.
Oct 23, 2013 | Tilia FoodSaver V2240
V3840 Food Saver won't vacumn
Hi valkenwil798
Go to the following webpage for parts to repair the vacuum part of the sealer
Please take time to rate me
Bud
http://www.foodsaver.com/parts.aspx?cid=0
Sep 30, 2012 | Tilia FoodSaver V2240
Gamesaver turbo will not seal bags
I had the same problem, the plastic nipple in mine was cracked, manufacturer defect and they don't make them anymore. Does anyone have a diagram of the inside of the food saver.
Sep 12, 2011 | Tilia FoodSaver GameSaver Turbo White
When replacing a bad gasket do you glue it on or what is the best way to adhese it to the preexisting rubber... v2240 food saver
Hi jab500...
I would recommend a good adhesive such as 3m Weatherstrip Cement or Contact Cement to glue the gasket in place. Use a small amount of cement, in case you want to replace the seal in later times.
By glueing the gasket in place with cement it will not come loose during use.
Sep 04, 2011 | Tilia FoodSaver V2240
Trying to find a gasket for ......food saver vac 820
Replacement parts for the Tilia Foodsaver products can normaly be found here:
http://www.foodsaver.com/parts.aspx?search=420
However I am having trouble with your model number. Are you sure it is correct?
Suggest you inquire with the company as to which listed model would be compatible with your model . You may contact them over the web here:
https://secure.foodsaver.com/contactus.aspx
Aug 14, 2011 | Tilia FoodSaver VAC420
My food saver won't vacuum. It worked beautifully last salmon season but now it makes a lot of noise but barely sucks.
Does it have the black rubber gaskets like my V845 Foodsaver? If so, make sure that you wet down the black rubber gaskets like with a wet paper towel before each sealing, and of course make sure the edge of the cut bag is between the two black rubber gaskets. Hope this helps you.
Sep 05, 2010 | Tilia FoodSaver V2240
Jan 08, 2010 | Tilia FoodSaver V2240
Tilia FoodSaver V2240 Logo
57 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Ed Mac
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
