Question about Canon PIXMA MP510 All-In-One InkJet Printer
My Canon printer Pixma MP510 won't print and is giving the following error indication - Auto sheet feeder - there is no paper; however there is paper and when I press OK it keeps giving the same error.
  • 3 Answers
Try re-installing the printer drivers
Posted on Oct 03, 2010
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
How do I print an envelope from the Canon MP150
  1. Do the following
    Open the paper support and extend the paper support extension.Open the paper output tray. Set the paper thickness lever to the right side for envelopes.Load envelopes in the auto sheet feeder with the print side facing up. Check the printing direction.Set the envelope in the direction of the arrow.Set the envelopes to the right side of the auto sheet feeder.Pinch and slide the paper guide to the envelope's left side .
May 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error code says 5c00 on my canon pixma mp500 printer. cant find my manual to figure out what the code means
The error code 5c00 usually means that there is a paper jam or paper path restriction.
If the path is not restricted, the printer will need servicing.
If you want a downloadable user manual for your printer go to
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=11995
Dec 11, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon printer
clean the feeder rupper or replace them
Jan 07, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
My MP510 grabs way to many sheets of paper.
hi i am a Canon certified repair tech for this printer. it seems that your problem is due to a broken sheet feeder unit. what i ahve seem with some new machines is that a plastic shaft that controls ther seperation of the pages breaks. most of these problems occurs with new machine because they are shipped from place to place. if the unit is under a year old it is still under warrenty and can be brought to or shipped to a repair center. even if its not under warrenty any longer you should still call Canon at 1-800-OK-CANON and complain that it has been doing it since you bought it and they will locate the nearest repair center to your location for you. hope this helps.
Jan 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
204 people viewed this question
old marine
old marine
