Question about Nokia 3650
Help me how to cut in two pieces
    Brigadier General:
  • 7,752 Answers
More information is needed pls
Posted on Jun 06, 2008
How do I cut an angle of 135
You would cut a 45 from the backside if the face side is to have a 135 degree cut. You will need trim up to the final cut.
Maybe this image will help explain it.
Mar 19, 2015 | Garden
A piece of wood that is cut in half lenghtwise.
Since none of the cuts affect the length, the length of each of the twelve smaller pieces it the same as the length of the original piece.
Sep 22, 2014 | Cars & Trucks
Stuck shredder
1. Turn the shredder off and unplug it. You DO NOT want to be poking round in those sharp blades and have it accidentally switch on!
2. Take the top off the shredder and place it on a big piece of newspaper, or somewhere you can easily sweep up mess.
3. Begin by getting a pair of tweezers and taking pieces of paper from one end of the shredding blades. This will loosen it up and give you more room to get the rest out.
4. Carry on tugging the strips of paper out. It helps if you don't just pull a clump, but wiggle it from side to side. This will get the whole strip out, not just the top.
5. If any pieces are curled around the blades and you can't free them, cut them with a knife and then tug them out.
6. Once it's mostly cleared, put the top back on and switch the shredder on. Put it in Reverse Mode so it will spit the last pieces for you to remove.
7. If it's cleared out, continue shredding:)
Hope this Helps!
Please Rate:)
Thanks,
Gary
Once
it's mostly cleared, put the top back on and switch the shredder on. Put it on
Reverse mode so it will spit the last bits back up for you to removeOnce it's mostly cleared, put the top back on and switch the shredder on
. Put it on Reverse mode so it will spit the last bits back up for you to remove.
If any pieces are curled round and you can't free them, cut them with the knife and then tug them out
.If any pieces are curled round and you can't free them, cut them with the knife and then tug them out
Jul 10, 2013 | Office Equipment & Supplies
Fix a piece of carpet that burnt
YOU FIND A PIECE OF CARPET THAT IS THE SAME. THEN CUT YOUR DAMAGED CARPET AROUND THE PERIMITER OF DAMAGE. THEN CUT REPLACE PIECE TO FIT THE AREA YOU JUST CUT OUT. GET SOME SEAM TAPE FILLTHE HOLE TO UNDERSIDE OF YOUR CUT HOLE AT LEAST A1/2 INCH AROUND THE INSIDE OF HOLE HEAT UP GLUE GUN AND FIT YOUR NEW CUT PIECE IN PLACE THEN RELEASE THE HOT GLUE UNDER ALL EDGES OF CARPET GOOD LUCK
Apr 05, 2013 | Washing Machines
Legthen sleeves on pattern simplicity 1945
usually the pattern is altered below the armpit area. Lengthening requires either tracing the piece and adding additional length by sliding the pattern piece the required amount. OR but cutting and adding in a piece of paper and retracing the cut lines.
This question doesn't really belong here... you need to go to a tailoring site. ;) I can suggest http://www.patternreview.com join and you will get lots of help from the forum pay a member fee and get online classes.
Aug 29, 2012 | Sewing Machines
How Do You Know If Your 10" Sawblade Is Running True, I Have A Powermatic 10" 3HP Cabinet Table saw. Please Help. Ps. I'm Not A Carpinter Or Cabinet Maker,Just...
Turn it on, and take a piece of wood, and make a "long-ways" cut half-way,
i.e., take a 4-foot 2-by-4, and cut half-way to making it into two 1-by-4 pieces, each 4-feet long.
If the blade is running true, then the cut will be quite narrow.
Otherwise, the cut will be noticeably wider than the width of the blade.
Feb 26, 2011 | Computers & Internet
I have Wahl vision 180 B & M trimmer M 9858, with 3 complete parts separated:a)a 1.5" x 1.5" flattish blk plastic & metal piece with cutting 'comb' at the end; b)a 1" x 1.25" Blk & metal piece...
It is very likely that one of the plastic pieces that hold the spring mechanism broke. If you send it back (with all the pieces and clipper) to Wahl Clipper, 2900 N. Locust St., Sterling, IL 61081, they will probably fix it for you for free.
Sep 17, 2009 | Wahl Vision 180 Beard Trimmer
Need a copy of page on setting up the Craftman miter saw model 113235120. There is one page in there with the set up to cut compound miters.
Make all cuts with molding flat on the table and bevel at 33.8 for ALL cuts ...to cut left inside corner, set miter at 31.6 degrees right. top of molding against the fence left side is finished piece... right inside corner set miter at 31.6 left with bottom of molding against the fence.left side is finished piece...left outside corner same setting, bottom of molding against fence right side is finished piece...right outside corner set miter at 31.6 right with top of molding against fence. right side is finished piece. hope this helps
Sep 01, 2009 | Craftsman Saws
Nokia 3650 Logo
14 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
