Question about Saeco D-XXDX 8-Cup Coffee Maker
Hi, My Saeco Venus from Starbucks is taking FOREVER to brew, 25-35 minutes and it evaporates half of the water in the process. In the last week I have cleaned it twice with the descaler from Starbucks, once with vinegar, rinsed several times and there is no change. What do I do? I have had this machine less than a year. Thanks for your time! Bekah Olson (253)651-0402
  • bekahmae Oct 04, 2010
    So, how do I do that?
    Genius:
  • 1,456 Answers
Hello
It is a possible mineral build up in your coffee maker that is causing the problem
Heres what you should do
Unplug the machine and remove the coffee container by loosening its two fastening screws. Pull up on the adjustment lever and turn the grinding adjustment ring until its two blue marks line up, which will let you remove the ring. Vacuum or brush out the machine's gear box and grind-ring support, and reassemble the machine.
Use a thin needle to check the steam/hot water spout hole for clogs. Steam and hot water will not be dispensed correctly when the hole is clogged.
Adjust grinder levels. Move the level lower if coffee is dispensed too quickly, and move it higher if coffee is dispensed too slowly.
Posted on Oct 04, 2010
  • Saeco Master
  • 1,711 Answers
There is a scale deposit in a point of the piping that is big enough so the descale solution cannot dissolve and the only way to remove it is to disassemble the machine and manual descale and clean the machine.
Posted on Oct 03, 2010
  • espressonist
    espressonist Oct 04, 2010
    You need remove the top cover and by following the water hose from water tank up to hot water pipe to filter remove pipes and clean them one by one. It will take time but is the only way and 100% gurantee.
I have a Starbucks Sirena - the grounds overflow in the basket while pulling shots, and it drips forever after it's done. When I remove the basket it's a huge mess every time. All the parts seem to be...
it sounds like you need a new group head gasket, or the group head gasket is not installed properly.
If it is a new machine, you probably just need to reseat the group head gasket. If it is a used machine, the gasket is probably worn, they need replacement every 6-12 months.
The Starbucks Sirena is made by Saeco, and is also called the Saeco Sirena.
You can find the group head gasket (brew head gasket), and any other parts from the following:
seattlecoffeegear.com
Here are a few videos of the machine in use:
http://www.youtube.com/SeattleCoffeeGear#p/search/3/6QlOKdAhElI
http://www.youtube.com/SeattleCoffeeGear#p/search/1/U8Lyomhq92Q
Mar 03, 2011 | Saeco Starbucks Sirena Espresso Machine
Last night I removed the brew head screen to clean it and then screwed it back in. (I did this because it was taking forever to get one shot of espresso). Now I can only get a trickle of water out of the...
HI
It sounds like you didn't get all the parts back in the head. The silicone head with the spring goes in first, then the screw. The spring has to touch the screw. Then the filter screws into the screw plug.
Jan 26, 2011 | Saeco VIA Venezia
Starbucks Barista (Saeco) Espresso machine Quit pumping
Hi
If it makes a noise when you turn the brew switch on you may have a blockage in the out let line. If it doesn't make a noise but every so often you may have a bad pump.
Mar 06, 2010 | Saeco Starbucks Sirena Espresso Machine
Can't get steam from the a Starbucks Saeco Italila Digital Auto
Hi If you can get water to flow from the wand, you can descale the machine. You might have a bad steam boiler. There is also a fuse on the boiler that might be bad. Set your water hardness to 4 to keep the machine working for a long time. Descale more often than not enough.
Jan 26, 2010 | Starbucks Saeco Italia Digital Barista...
Won't heat up
Hi
Have you run water through the steam wand on the right. Make sure that you have water in the water tank and the pick up tube is in the water. Open the knob and then push the brew button.
Oct 21, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco Italia water lite and green lights flashing
Try to open the steam knob and make a cup of water (tea), see if you can get a full cup or just a half.
How old are your machine?
How often do you descale the machine?
Best regards
/Mirran
Sep 05, 2008 | Starbucks Saeco Italia Digital Barista...
Water in the coffee grounds drawer
Look for a leak near the brew group on near the piston area.
Changing the brew group should solve this problem.
http://cerinicoffee.com/item.asp?cID=0&PID=206
Johnny C
www.cerinicoffee.om
Oct 01, 2007 | Starbucks Saeco Italia Digital Barista...
Saeco D-XXDX 8-Cup Coffee Maker Logo
174 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
