Question about GE Dryers
Ge dryer gets hot but doesn't dry> cleaned everything in and out. belt seems fine and tumbler tumbles. any ideas
  • sharon brumlow Oct 03, 2013
    I can turn the drum by hand.
    Sergeant:
    Champion:
  • 351 Answers
Check vent maybe stopped up
Posted on Oct 03, 2010
2 Suggested Answers
  • 454 Answers
SOURCE: Today our dryer quit drying. It hums but is not tumbling.
Dryers are belt driven. Something has locked the drum or motor, and that is why you hear the humming sound. With the dryer turned off, reach inside the drum and try to turn it. It should turn pretty freely. There will always be some drag. If you need a lot of effort to turn the drum, then it is time to investigate what is causing the drag. Probably, something has gotten wedged between the drum and the front wall of the dryer.
If you cannot find anything there, then it could be helpful to remove the outer shell from the dryer and investigate further to find the source of the drag. This requires some mechanical skill, so think carefully if you want to try it or call a service company or simply replace the dryer. A used dryer can cost $100 or less.
Posted on Feb 16, 2010
Wt881 gorenje tumble dryer
Hello, I have a problem with the dryer, it doesn't dry to clothes off and everything else works fine. What seems to be the problem and how can I check it on my own? Is it the heather, the thermostat or something else maybe?
May 26, 2011 | Dryers
My 80 series Kenmore Dryer is heating up, tumbling, but my clothes aren't drying. It's taking 6-7 cycles to get anything dry, I have checked the vent hose and everything. All seems to be checking out ok....
You need to check your vent, or your vent system in your dryer. You also need to check to see if your clothes are tumbling. If not then your belt could be broke. Good luck!
Aug 21, 2010 | Dryers
GE DSXH43EAWW dryer stopped working mid cycle
unplug it,take it apart and check it out,you could have snapped the belt,there's a belt switch so if the belt breaks the dryer won't start,or if you haven't taken the dryer apart and cleaned it out and also the vent line you could have popped one of the t-stats,only way to tell is by checking them with a meter.the dyer should be cleaned out once a year ,if not the air can't move freely and one of the t-stats will pop as a safety,the dryer will run to hot and take out the thermal fuse or the high limit t-stat,if it's been taking longer to dry the clothes or if you see lint stuck to the bottom of the dryer door these are signs of bad air movement and the dryer and vent line needs to be cleaned out.
Dec 30, 2017 | GE DSXH43EAWW Electric Dryer
Dryer wont tumble when loaded.
check for a "glazed" drum belt or a broken "idler" pulley near or on the motor that keeps the belt tight on the drum
May 10, 2010 | GE DBXR463GB Gas Dryer
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
Dryer was working fine before I left on vacation, came home and dryer has power, but it won't tumble. Timer seems to work for a few minutes then everything shuts down
HELLO im18; It may be sensers around the heating element that may have triped because there is a belt BROKEN that drives tumbler, and the air fan as well. You may have to get someone that knows about these things too fix it as well,sorry. John.....!
Aug 20, 2009 | Kenmore Dryers
I have a GE Frontloader Dryer, model# SBSD227FWW
common problem result from you having a clog in your home vent.....wil need to check outside vent while unit is running on air dry for air flow....could also be a vent motor failure....depending on unit it may have a motor just for the exhaust fan.
Jun 30, 2009 | Dryers
No tumble action, belt seems fine
the belt has to be replaced
May 12, 2009 | Dryers
GE Dryer makes deep sounds when hot and tumbling
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Dryers Logo
59 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
