Question about Sub-Zero Refrigerators
I have a subzero side by side refrigerator. Model #680. The lights are nfreezer section are working fine. Ther refrigerator side has no lights working. the display panel as well is not lit.Food in refrigerator side is cold. I vacuumed compressor so it is clean. How do I restart the lights and display on refrigerator side?
  • kathykleyn Oct 03, 2010
    Actually...it is fixed. I vacuumed the compressor and now all the lights are on working. It must have shut down until I cleaned the compressor.
    Thanks
    Kathy
  • 2,272 Answers
Yes its common when vacuumed the compressor the lights may not work for a particular time period. exactly It must have shut down until I cleaned the compressor. good to know its fixed.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
thanks for your appreciation.
Posted on Oct 04, 2010
    President:
  • 2,047 Answers
Usually if the lighting has major problems it affects both segments of the unit. But in this case only the fridge seems to be affected this narrows the problem down to one of two things.
The first being the bulb for the lamp. Check this and if possible get a replacement bulb.
The other will be the switch which controls the fridge segment this will need an expert touch. But shouldnt cost too much.
Hope this solution has been helpful?
Posted on Oct 03, 2010
  • Rockme
    Rockme Oct 04, 2010
    Thanks for the feed back. It has added immensely to my knowledge.
    Please endeavour to rate the response provided.
Need Users Manual
THis is as closes at I could get to your model, I hope this link works for you.
Good Luck
SubZero Manual
Sep 09, 2013 | Sub-Zero 680 / F
Refridgerator side is freezing food. I can't turn down temperature panel buttons are not working.
Do you have ice on the rear panel to your refer section? If you this is repairable but will take a certified person to repair correctly. That means you will need to call a service person to have your evaporator and direr replaced. I would have t also assume the ice would be located in the lower section and more toward the left side, normally starts around the meat door. Is seems to be common when the unit reaches about 10 years old, the factory warranty is 12 years on parts. I would verify first and then ask SubZero directly for a servicer in your area, 1-800-919-8324. I always call to verify warranty status prior to working on these units, they are alway helpful to a servicer.
Good Luck
Aug 21, 2011 | Sub-Zero 680 / S
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero 680 - vacuum condensor message won't go away.
You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that should clear the fault code.
Aug 16, 2009 | Sub-Zero 632 / S
Please reference SubZero Model No. 680. My
OMG DO NOT TAKE THE DOOR APART!!!!!!! The water line is not in the door. It comes from the valve on top of the unit into the fridge behind the control. Make sure that the drain behind the crispers isn't blocked causing your leak.
Jul 20, 2009 | Sub-Zero 680 / S
HOW DO WE INSTALL CONTROL BOARD IN A SUBZERO REFRIGERATOR MODEL 680
Go to this site enter this number in the model search feature. Model number ARSE67RBB then on left of screen choose picture #3 controls and click that picture this gives a photo of how the parts go together. Hope this helps, if not, just let me know, Thanks, Sea Breeze seabreezehvac@yahoo.com
click link below.
http://servicepartstec.blogspot.com/
Apr 28, 2009 | Refrigerators
Sub Zero Model 680 - Light in Fridge and Control Panel out
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Sep 01, 2008 | Sub-Zero 680 / F
Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Mar 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
76 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
