When i go to print, the paper keeps getting jammed. But there appears to be nothing there!
    Problem Solver:
  • 4 Answers
Try taking all the paper out, turn the stack around, and put it back in. Sometimes the **** is bent ever-so-slightly, and turning it around helps it to not jam (at least that has helped me). Sometimes the problem is static electricity. If that's the case, fanning the stack of paper might help. Or, you can gently bend the **** longways (holding the stack on both ends), pinch the edges and straight it back out (so all the pages separate), this helps too (sorry, it's difficult to describe that in print rather than be able to demonstrate what I'm trying to say). Good luck!
Posted on Oct 03, 2010
SOURCE: Paper jams
I had the same problem and fixed it by giving the printer a good cleaning and turning the paper pickup tires (under the front of the printer, above the tray) inside out (they were showing some wear).
Posted on Jan 17, 2008
  • 390 Answers
SOURCE: PAPER JAM
Hi, oh dear, you have a paper jam in or near the roller or very small one in carriage. Open up unit as if rplacing cartridges, get a torch if you have to and search for tiny jam. A good clue, is does the carriage return to correct positon upon opening?
Posted on Feb 10, 2008
checkitright
  • 1362 Answers
SOURCE: Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Posted on Aug 25, 2008
  • 34 Answers
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
Posted on Mar 14, 2009
  • 51 Answers
SOURCE: paper jams??
click here to download yor required drivers
Posted on May 12, 2010
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Paper Jam keeps appearing
At the print driver there is a paper size selection before you print.Select the proper size and weight and it will work fine for you.
Jul 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Paper jam
ya open the front dor and remove cartidhe then check there is not any paper jam then refix cartridge .also check in back side of printer that tyhere is not any paper jam .
thats all.
Nov 10, 2008 | Canon PIXMA MP470 All-in-One Printer
Printer is not working
Try pushing the print head carriage with a bit of gentle force. It is getting stuck, and hence the error. You may have to open side and top covers to reach this. Note: this is not the cartridges, but another device that moves back and forth on the slider carriage.
May 15, 2008 | Canon Office Equipment & Supplies
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
21 people viewed this question
k24674
