Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
I have a ventless heater, my house is covered in black soot, i also have a carbon minoxide detector it's never went off, what is it?
    Problem Solver:
  • 9 Answers
Your ventless appliance probably needs cleaned-the combustion burners and air passages need blown out with compressed air or vacuumed. also ensure you have supply of outside air into your house. if your house is sealed up pretty tight you need to crack a couple windows to let air in. There is no such thing as a truely "ventless"..what they mean is ..properly maintained and operated ventless heaters with proper ventilation are safe to use inside. also be aware that other chemicals in the air of your house from candles and air freshners, cleaning agents, etc will burn in the ventless heaters creating toxic pollution.
Posted on Jan 08, 2011
Pilot light ignites, but does not stay on when I release and want to push to the right position to warm the water
Most gas heaters have a heat detector set in line with the pilot flame. Sometimes this can become covered is soot or carbon. Clean with sand paper 120 grit or less
Apr 11, 2015 | Water Water Heaters
Smoke and soot from my pleasant hearth stove
Your chimney must be properly installed above the roof line to prevent downdraft. The soot issue may be cause by burning wood that is too green, not dry enough to burn clean.
Safety is a concern when using a wood stove in your house. Be informed about the dangers of Carbon Monoxide Poisoning.
http://carbonmonoxidedetectoralarms.com/
Carbon Monoxide Detectors are mandatory by law in some states. Protect yourself and your family.
Amazon com carbon monoxide detector Electronics
Mar 23, 2014 | Pleasant Hearth Home
Why gas log fireplace releasing black soot
Logs are likely not placed properly on the burner. Option two is if they are a vented gas log soot is normal, but only on vented sets. Unvented Logs will be soot free. Soot is a sure sign of Carbon Monoxide. Install a detector if you do not have one.
Dec 30, 2012 | Desa International Heating & Cooling
Smoke fills house when furnace turns on
Assuming not talking soot smoke . new furnaces have a coating on heat exchanger from productions which must be burnt off. Generally the contractor will run unit long enough while on job with customer venting home at same time. should not take to ong to do so if this is what you are experiencing. and dont forget to install a quality carbon monixde detector or 2 as per detectors instructions.
Nov 25, 2012 | Heating & Cooling
My nighthawk carbon minoxide detector reads and is beeping interminently ERR
Allow fresh AIR to flow into and see if the error message changes, maybe blow into fresh air. If not there is fault in the sensor or a poor calibration of the sensor, failure of the detector processor unit.
Dec 14, 2010 | Heating & Cooling
How long does the nighthawk model carbon monoxide detector last for.
I had 2 and they both did the ERR thing and stopped working within a week of each other and that was about 7 years.
Nov 20, 2010 | Kidde Nighthawk Combo Gas/co Detector
What causes black soot to smoke up our complete house with ventless logs
Take the pilot and burnner assembly all apart and blow it out with compressed air then reassemble and make sure that the air shutter is totally open. The soot is cause by a bad air/fuel misture that is too rich and cause carbon to form from incomplete combustion. If the burner continues to make soot then reduce the gas pressure to the gas log at the pressure regulator.
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 24, 2010 | Empire DV-215 Direct Vent Natural Gas...
Smells like it is running rich and it does not seem to be getting as hot as my other one strong smell and burns your eyes
Whatever it is sounds like you should clean it... carbon and soot build up in exhaust... if it is a ventless (which is info you should have asked about) than you will find that it is the second heater in line and is starved for fuel.
Nov 27, 2009 | Reddy Heater RLP100 Portable Forced Air...
There is black soot on my walls and ceilings above my baseboard heaters. Is there a solution or a reason as to why this is happening? Is there a part that needs replacing? We are desperate for a solution....
In my experience soot in the house is (almost) always caused by the burning of candles. Get a CO detector if you don't already have one! You see the soot at the heaters because of the air flow they cause. There is nothing in a baseboard unit that could cause soot. Just water.
Mar 30, 2009 | Fahrenheat Electric Convector Baseboard...
I have black soot on my walls from my baseboard heaters, is this hazardous or dangerous to my health?
same issue years ago. these heaters draw air in from the bottom and push it out the top. so any dirty air (candles burning will do it) is pulled through the heater and pushed out the top causing stains on walls.
Jan 01, 2009 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
210 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
