Question about Maytag Atlantis MAV6000 Top Load Washer
Washer fills very slowly when using only cold water
    Sergeant:
    Champion:
  • 351 Answers
Screen in water valve need to be clean take cold water hose off and look inside valve you will see screen
Posted on Oct 03, 2010
My Roper heavy duty 8 cycle 2 speed combination washer does not fill up on rinse cycle
when in rinse washers use just cold water so clothes don't wrinkle,try this,set the washer to just cold,start it and see if it fills or fills slowly if so you have a bad water valve on washer or no cold water going to washer.
Dec 04, 2017 | Roper Washing Machines
Cold water fills very slowly
Possible the INPUT FILTER of the COLD water is clogged or the INLET valve is faulty. check the power from the board.
Jan 02, 2013 | Roper RAS8445KQ Top Load Washer
Water for intial fill works fine . when it goes to rinse cycle the water just dribbles in making wash time go on for ever ! whats the solution?
when you start the washer set it just on cold and see if it fills slowly,when the washer goes to rinse it just uses cold water,you could have a problem with the washer or in the house,when you run it on just cold and if it dribbles in,stop it shut down the water going to the washer,remove the cold water hose from the back of the washer,stick it in the sink or inside the washer and turn it on,if it comes out strong then you have a bad water valve on the washer,if it comes out slowly you have a bad water valve in the house and it's not the washer.hope this helps
Sep 12, 2011 | Washing Machines
Turn off the water, remove the cold water hose at the back of the washer ... inside you will find a hose washer with a screen on it - remove and replace it. I believe you will discover the screen is clogged. While you have the hose disconnected, run some water into a bucket from the hose to clean it as well.
Jun 19, 2010 | Kenmore 24032\24036 Top Load Washer
Water comes out verryy slowly when using cold wash GE large capcity washer
check the fill hose washer located in the washer cold water fill hose,they get clogged with lime and such,and when you replace the washer run hot water thru the hose to clean it out thoroughly,
Apr 24, 2010 | GE Profile WPRE6100G Top Load Washer
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My Kenmore 110 92587210 Washer is slowly letting water in
The solenoid for the cold water valve has failed in the open position and needs to be replaced. The valve unit is for both hot and cold. It is the item that the water hoses are connected to.
Aug 26, 2009 | Kenmore 24032\24036 Top Load Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Cold water enters washer very slowly
First - check the water inlet hose screen for calcium or rust build-up.
If cold water is filling slowly, take these steps:
  1. Unplug the washer.
  2. Turn off the cold water supply faucet.
  3. Remove the fill hose connected to the back of the washer.
  4. Checkthe fill screen on the cold water inlet valve for debris or depositsthat can restrict the water flow. If necessary, you can carefully pullthe screen out and clean it. Flush the inlet thoroughly and replace thescreen. NOTE: If debris makes it past this screen, it can cause thevalve to leak and cause a flood in your laundry room. Monitor thewasher for this type of problem is you pull the screen out and clean it.
  5. Placethe end of the hose in a bucket and briefly turn on the faucet to checkfor proper pressure and flow from the cold water hose. If waterpressure from the cold inlet water hose is bad, check the hose forclogs. If the hose is okay, then I recommend calling a plumber to checkthe water supply to your washer cold water faucet.
  6. If the above checks do not help you resolve the fill problem, you will likely need to replace the inlet fill valve.
Your cold water fill valve (mixer valve) solenoid has failed if after cleaning - the condition remains.
CLICK HERE for a replacement part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 24, 2009 | Roper RAS8445KQ Top Load Washer
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
