Question about Kenmore Dryers
I have the Kenmore Laundry Center (the dryer is on top of washer). When dryer gets heated up it makes a very loud Squeeking noise.
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Posted on Oct 03, 2010
Makes a ticking or clicking noise when dryer is on. How can I fix it? The heat and tumbler still works though.
Hi Lisa, thank you for your post!
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
Dec 12, 2013 | Frigidaire FEX831CS Top Load Stacked...
My dryer is making a very loud, constant squeeking/squilling sound. I took apart the front and top and examined the belt. The belt is fine! The dryer works but even wth my laundry door closed, it is really...
In the back of the dryer there is a ball bearing unit that it rotates on... I have changed these before,
and they all made the same noise you described.Most dryers ( ALL TYPES ) have the same basic design.......This should be your problem....I think they are about 30 or 40 dollars..kinda hard to change also...you will need plenty of room to work in and maybe an assistant to help hold it in place because it has to be centered.
Feb 20, 2011 | Dryers
Dryer makes loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 18, 2011 | GE Spacemaker Washer and Dryer Electric...
The belt in my dryer is squeeking. What type of
It's probably the front tub guides that are worn out causing the squeak. It's a felt lined circular shaped guide that holds the front of the tub. The rear of the tub is held by a ball and socket bearing. Access to the guides is behind the front panel of the dryer. Remove the screws across the top
May 10, 2010 | GE Spacemaker Washer and Dryer Electric...
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Sep 09, 2009 | GE Dryers
Kenmore laundry center
There is a thermal limit fuse on the rear of the machine.
Check it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore Elite Oasis 110.2706 Top Loader Grinding Noise
If you remove the back panel, there are two pumps towards ethier side at the botom of the tub. If you remove the back hoses (have some towels ready) You may find something in one of the two pumps.
Jun 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Dryers Logo
64 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
