Question about Garden
Victus 51 chainsaw manual - Garden
How do you put the throttle linkage on to the carburetor on a model 51 w/zama carburetor?
Husqvarna 51 55 zama Chainsaw Carburetor
if like most carbsy connected before fitting
looks like only one hole for a wire or throttle cable
Nov 02, 2016 | Garden
Starts but stalls when hot. Chain is not too tight
Larry,Carburetor may be dirty, remove and clean or rebuild. Check the attached links,videos,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna Chainsaw 235Troubleshooting Repair Help
How to Troubleshoot Husqvarna Chainsaw Problems eHow
Husqvarna 136 Chainsaw Carburetor Rebuild Fuel Line Repair
http://www.mymowerparts.com/pdf/Husqvarna-Service-Repair-Manuals/W9200002.pdf
Apr 19, 2016 | Husqvarna Chain Saw Models 51, 55
How old is my chainsaw
From what I can find out the 51 model was made between 1991-2001
Mar 23, 2016 | Husqvarna Garden
Husqvarna problems
If spark is ok then I would say the carburetor is the likely problem or the fuel is not entering the engine. Something like the following instructions might help.
How to Adjust Husqvarna Carburetor eHow
Look at this manual for model 51 carburetor adjustments.
http://www.getsaws.com/PDFs/w9600001.pdf
Aug 06, 2014 | Husqvarna Chain Saw Models 51, 55
HOW TO SET CHAINSAW TIMING
There is not a method to set timing. The flywheel is keyed for location. The ignition module can be moved slightly but the effect will be minimum. If you are having backfires or think timing is wrong. Check the key and make sure it is not sheared.
May 24, 2014 | Husqvarna Ignition Coil 55 257 245 51 254...
What is a convertable drive on a 1964 homelite 51?
Do you mean a C-51? It might be a gear driven low speed saw. I had an old homelite years ago.
Try this posting your question to this forum:
Chainsaw Collectors se
Apr 24, 2014 | Homelite Garden
The Husqvarna chain saw models 51 and 55 does not starts.
Is this about two different chainsaws? You will need two different posts giving the particulars about each saw.
Sep 15, 2012 | Husqvarna Chain Saw Models 51, 55
Chainsaw Service manual for Husqvarna in New Zealand
here's a Contact in your Area:
Husqvarna New Zealand 15 Earl Richardson Avenue, Manukau City Auckland
Auckland
New Zealand
Tel: +64 9 920 2410
Fax: +64 9 920 2429
Web: http://www.husqvarna.co.nz
E-mail: carol.osborne@electrolux.co.nz
Nov 17, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
