Tv channel says this channel should be available shortly Ref code;$0a00
It means your Bill isn't paid. Call during business hours or not and you are told you need to pay your Bill
Posted on Oct 07, 2010
I have not had any programs through Comcast in Kokomo on my T V since the wee hours in the morn. 3-12-17 Just says " one moment please this channel should be available shortly Ref code S0a00
Suggest disconnect power from cable box. Wait 10 minutes. Connect power allowing cable box to reboot,
If not successful contact cable service provider. The cable service may have a problem.
Hope this helps?
Mar 12, 2017 | Comcast Televison & Video
Trying to connect a DVD player to a TV that is only equipped with a cable jack what do I do
You need an A/V to RF adapter to convert the audio and video outputs of the DVD player to RF so that you can watch the DVD player on an available VHF channel on the TV. See this device offered by Amazon:
RF Modulator TV Switch Audio Video RCA Ant Input to Type Coax Output...
You may also need a short 75 ohm length of coaxial cable with "F" type connectors on both ends and A/V cables with RCA plugs to complete the setup.
Jan 02, 2015 | Televison & Video
What are sceptre tv codes
one of these should work 10878, 11217, 11360, 11599
ref:http://media2.comcast.net/anon.comcastonline2/support/help/faqs/remotes/DTAmanual.pdf
May 11, 2014 | Big Button TV Universal Remote
Two sets of Motorola Walki Talki radios will not communicate.
In addition to the channel and privacy codes, some Motorola two-way radios have a feature called Eavesdrop Reducer where you have 3 scramble settings available; perhaps you have this set on one of sets of radios but not the other. It should be something like that because otherwise there is no reason that by setting the radios to the same channel and privacy code they wouldn't be able to send/receive to each other.
Nov 24, 2013 | Motorola Walkie Talkie 2-Way Radio
A lot of stations say this channel will be available shortly ref code s0a00
if yall give me a zcard ill live yall aloen mom no your not me yes i am no yes please
Jan 10, 2011 | Sanyo Televison & Video
Car wont start after sitting for 6 hours runs like new if you start it before 6 hours codes p1496 always there when it fails to start.
Yes the car will fail to start due to this error code p1496.Its possible. Description of code P1496 is 5 Volt Supply Output Too Low. But to locate the exact fault you will need to do some troubleshooting. The 5 V ref. can be low for a couple reasons. 5V is supplied to several engine sensors, like the crank, cam, Map, etc. It's not uncommon on chryslers for one of the sensors to short the 5 V. reference voltage and get that code. To check if a sensor is bad and shorting the ref. just check for voltage on the 5V ref as you unplug each sensor. If the 5 V. ref. returns, the last sensor you unplugged is the shorted sensor. It's usually the crankshaft sensor, but not always. If the 5 V. ref. still is shorted after unplugging all sensors that receive 5V. ref, check for 5 V. at the PCM. If it's present at the PCM, there's an open or short after the PCM. If there isn't 5V ref at the PCM, it's probably a bad PCM. That is a 5 volt supply too low. You will want to check the connections at the MAP and TPS sensors. --------
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Sep 22, 2010 | 1999 Chrysler Concorde
I need a sky remote control code for a UMC LCD Television, Model Ref: S19-4NG. I have a Rev 8 sky remote control. Sky tell me on their web site that I need to upgrade my RC. I have the latest version 8!!!!
Most remotes work the same when programming an item. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 23, 2009 | Televison & Video
Need codes to access TV menus
The solution relies with the remote. press the menu button and use the +/- buttons beside it instead of the volume or channel buttons. This TV was at a work camp in northern Alberta and the instructions were not available. Hope this helps others who do not have instructions available.
Apr 18, 2009 | Toshiba 13A25 13" TV
Sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to imr4@in.com
Aug 12, 2008 | Sanyo DS24205 24" TV
Televison & Video Logo
824 people viewed this question
Top Televison & Video Experts
