Question Can anyone tell me where i can get a pico Pf 751 fuse from i have tried the net and i have tried alot of eletronic places and no one seems to have them i can order on line but i have to buy them in bulk i jsut need one plz help me
    Problem Solver:
  • 45 Answers
Http://cgi.ebay.ca/2SC5707-C5707-Transistor-LOT-OF-4-PCS-E172FPB-E173FPB_W0QQitemZ320251901100QQihZ011QQcategoryZ4666QQcmdZViewItemQQ_trksidZp1713.m153.l1262
That person sells the power transistors of the LCD and Pico Fuse. He sells them sepereatly but his site is not working this time.
Posted on May 30, 2008
What are the specific pico fuses for my RPTV
The amperage is marked on the board right next to them--likely if they go to the convergence circuit they will be marked 5a or 5 amp.
Usually but not always there are more at the convergence chips.
I presume you did not look closely at the board where the two you found are---Sony marks everything.
Jun 15, 2012 | Sony Televison & Video
I've replaced my STK's, 2 pico fuses on the G boards, and tested each convergence resistor along with the pico fuses on the D board--albeit they were still soldered in place. I desoldered two pico fuses...
I believe there is a power board on the left side when looking from the back. It will be vertical, right next to the board you worked on. Take that board out. I believe there are about four pico fuses on that board. One or two of them will be open. Replace the fuses and you should be good to go.
Feb 19, 2011 | Sony KP-57WS500 57" Rear Projection...
One of the tiny fuses in my Viewsonic VX900 monitor has blown. What is its part number, and where can I purchase a replacement? In addition, if I have to replace the entire inverter board, what is its...
I replace the surface mounted fuse with axial-lead fuse, PICO fuse made by LITTLEFUSE. You can try using a 1 Ohms 1/2 watt flame proof resistor in place of the fuse, if the resistor get real hot and burnt up then it may have shorted Transistors or transformer. You can get the number of the board and go to www.lcdparts.net to see if he has the inverter board in stock.
http://s807.photobucket.com/albums/yy352/budm/PICO%20fuse%20by%20Littlefuse/
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 03, 2010 | ViewSonic VX900 19" LCD Monitor
I have a rear projection Toshiba 42 inch and cannot get convergen
Sounds like convergence should replace chips marked Q 751 and Q752 part numbers ( stk392-110) check restors 1.8 ohms 1 watt rateing should be marked on board as R 7721 and so on, should more than one in the area of the ic. Look to see if there is some small fuses in the area also. They dont look like a normal fuse may be yellow or green black marked F on board around the ics these fuses are called pico fuse.
Feb 01, 2010 | Toshiba 42H81 42" Rear Projection...
Convergence parts? What are the specific pico fuses and resistors
There are six 3.15 amp picos use 3.5 amp when replacing and there are two 5 amp picos on the G board the resistors if needed are 4.7 ohm 1/2watt
Sep 06, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Pico fuse
They are usually 3.5 amp picos depending on what circuit they are in. If you go to this link and leave a email with your model number and pico number such as PS321 they will tell you which rating you need and they have all picos for sonys instock.
http://servicemanuals.vstore.ca/
Jul 07, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Samsung HCN4226 Convergence IC Problem.
The problem is likely to be the digital convergence board that generates the convergence signal that is amplified by the output ICs.
Jun 22, 2008 | Samsung HC-R4755W 47" HDTV
Hitachi 60sbx78b Won't Turn ON...need advise
If cap value is 1000 pf ( 102k ) 2KV, beef it up ! I use Sony part # 1-161-754-00 ....102k 3KV.......Note: sometimes shorted cap
is hiding under dried gob of placement glue............
Make sure pico fuse is correct amperage.......T.
Jan 28, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Toshiba CZ32T31, Vertical Deflection?
Usually the solder joints on the vertical output IC crack and the little pico-fuse opens. Resoldering the IC and replacing the pico fuse should bring the picture back. If you have never heard of these parts before and have no idea how to find them, then allow a qualified tech to handle it for you.
Aug 09, 2007 | Toshiba CZ32T31 TV
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
