Question about Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
The piston on my framing nailer is stuck in the "out" position - how can I fix the problem?
    President:
  • Stanley Master
  • 1,388 Answers
Assuming no air leaks, could be as a result of several problems. Things to check/try. Push driver up manually to full top position. This will reset the driver if it was stuck due to nail. Check for other debris in path of driver. If it very difficult to push up you will need to remove head and pull driver to check for bent shaft. If it pushes up easily and drops back down under its own weight, it needs a piston oring. If it pushes up easily/light force and stays up, fires once and stays down, then you need to replace the check valve (band or oring on the outside of the cylinder covering a row of holes). Parts are available at www.toolpartsdirect.com
If very stuck, I use a piece of driver that fits perfectly into the bottom of the gun and hit with large copper or brass hammer. If you must use a heavy hammer, remove the head and place body of gun on wood to prevent damage. Good luck
Posted on Oct 03, 2010
Piston wont retrace TO READY POSITION
Maybe there can be a problem with a rip in the cilinder its a very thin cilinder and its neccesary to replace with all the parts on it because of the extreme heat build up.
cilinder assy 42 41A possible necessary, but first inspect the cilinder carefully on a rift. some other rings or parts broken or worn.
Hitachi NR90GC 3 1 2 Gas Powered Clipped Head Framing Nailer Parts
Oct 02, 2016 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Why doesn't the trigger do anything on my NS289000 framing nailer?
Nailer not firing is caused by lack of lubrication in the headvalve (lube with white grease) or driver stuck/bent (make sure driver moves freely) or safety foot not depressing the firing pin on the trigger valve all the way in. Easy to check. Remove the trigger to expose the firing pin. With no nails in gun, connect air and depress the firing pin with finger all the way in. If the gun fires, adjust the safety foot. If the gun does not fire, lube headvalve and check driver piston stuck. Good luck
Dec 03, 2013 | Campbell Hausfeld Ns2890 Framing Nailer...
I have a new Bostitch F21PL framing nail gun. I used it for the first time on Saturday and it worked flawlessly through the first half-dozen nail sticks. Then, it jammed. The culprit nail was easy to...
when you removed the jammed nail did the piston driver move back into the rear position? if not there may still be a piece of the nail holding the piston.... If the piston is stuck in the forward position with the air disconnected use a hinge punch and tap it back, reconnect air and give it a try
Sep 23, 2013 | Stanley Bostitch F21PL Nailer
My bostitch n88rh framing nailer will fire when pointed down but wont fire pointed horizontal.
Nailers are made to use in any position so must be something simple to fix. Most likely safety contact foot, to test, remove the nails, remove the trigger to expose the firing button on the trigger valve. Connect air and dry fire onto wood or old coiled rubber hose in various positions. If the gun tests ok then carefully examine safety foot mech. and trigger for loose components missing guide or roll pin. The contact foot must push firmly up on the lever within the trigger thus pushing on the firing button. If the safety foot and trigger are in good conditon and working ok, then problem is within the headvalve and piston orings. To test piston oring, remove airline and nails, point nailer up then down again. The piston should stay in the top position. If the piston moves up /down with movement of gun, replace piston oring. If piston oring ok, remove the head and pull out the headvalve. Apply plenty of silicone paste or white grease to orings on headvalve and reinstall and test. If tests ok, then problem is worn orings in the head /headvalve. You can keep lubing or replace orings. Examine the surface within the head where headvalve orings make contact. If there are many fine scratches, even new orings will not work very well. Try to remove scratches with very fine sandpaper. Good luck
Apr 29, 2012 | Stanley Bostitch N88rh Framing Nailer...
Dewalt 51822 framing nailer acts like trigger is stuck. After I fired a nail the piston did not retract and there is air coming from the exaust. I disconnected the air supply and removed all the nails to...
Generally when the trigger makes a pop sound when you fire the gun and driver does not activate is indication of failed orings. There are two orings on the trigger firing pin and two orings on the cylinder that are made of vinyl and fail. All the other orings in the gun are black rubber like compound and last for a very long time. The two orings that fail within the gun are included in the repair kit and the trigger valve will most likely need to be replaced, or you could remove the valve and change out the two small orings (2 x 1.5 mm). If you would like to attempt repairs, email and I will give you detailed instructions. Main problem is that the replacement orings will be vinyl also and will not last very long. Good luck
Jun 09, 2011 | Dewalt D51822 Clipped Head 2Inch to...
I can get he gun to shoot 1 nail but won't load the next nail?
There is a small piston on the side of the magazine that pushes the feeding claw which pushes the next nail into place. Either the feeding claw or piston is stuck or the piston is worn out and needs to be replaced.
Sep 30, 2010 | Stanley Bostitch Coil Framing Nailer
Not firing right
the nail return spring for the piston is stuck or broken,dis mantle the gun and clean and check the spring to see if its broken
Apr 06, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Porter Cable FR350 Round Head Framing Nailer not firing
check and make sure your compressor is at the right psi. 120psi. is there any nails stuck in it. there may also be a problem with the seals.
Mar 08, 2010 | Garden
Firing Pin doesn't return
The piston is returned to its firing position by air from the trigger valve after the piston has fired. It relys on the piston sealing against the bumper at the bottom of its stroke, if the bumper was damaged when the driver shattered or it was put in upside down the piston will not return. Also the piston uses air fed into the return chamber from the little holes in the cylinder, if the seal over these holes is damaged the piston may not return. Basically change the bumper and the check seal on the cylinder.
Jul 28, 2009 | Stanley Bostitch Coil Framing Nailer
Roofing nailer blows air does not nail
Piston probably stuck,you can try some air tool oil and pull trigger to let it flow in and let it sit a bit upside down. try that,good luck!
Jul 16, 2009 | Stanley Bostitch Coil Framing Nailer
Stanley Bostitch N88rh Framing Nailer Driver Piston 158582 Logo
188 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
