Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Regardless what I do I can not reset the change Filter message and this is a problem on both of my 44660 thermostats. I followed the proceedure in the manual.
I have a solution!!!! Ok, hit the filter key. You will see the filter counter screen. Hit and hold the RET/CLEAR key until the Filter flashes and it clears the counter. I just found it by trial and error. I wrote it inside the cover so I could remember.
Posted on Dec 24, 2010
  • Tabitha Oct 26, 2011
    Thank you sooooo much!!!! You have just made my me so giddy!!! I am so glad this worked, it will be nice to actually be able to use the filter indicator and not have it flashing all the time!
Thermotast WX PSP511LCa says Change filter? What does it mean??
The thermostat records how long the blower motor in the furnace runs for and after a certain number of hours it displays the message to change the filters in the furnace. When you change them then you reset the thermostat. http://www.luxproproducts.com/pdfs/PSP511LCa_NL_ENG_Manual1.pdf
Apr 22, 2016 | Heating & Cooling
Carrier model FCBNF030 where is the filter located in the unit?
There may not be one. Most filter messages on a thermostat go by accumilated run time. They are just a reminder and the thermostat message has to be reset. If its there it would be at the unit inlet were the return plenum connects to the unit. They dont usually have both if you have filters in the return grills you dont need them at the unit.
Jan 13, 2014 | Carrier Heating & Cooling
Warning message for lamp replacement appears at each power up!
After replacing the lamp, make sure the lamp cover is securely closed. Select the Lamp Replacement option in the menu, (MENU > Settings > Setup menu) and follow the on-screen procedure.
Apr 20, 2017 | Sony LMP-H130 Projector Lamp Projector...
Upstairs Lux Programable thermostat has "Filter" message. FIlter changed. Does system need service or how do I reset for message to go away?
You should be able to flip the front cover door down on the thermostat and it will have a button that usually says "filter reset". Push it and it will go away.
May 13, 2011 | Heating & Cooling
On the thermostat the "filter"
Thermostats used in homes sometimes have a timer built in which will remind you to change your furnace filter. Most of them can be adjusted or disabled. The thermostat has no way of knowing whether the filter is actually dirty, it just reminds you every so often by flashing "filter" on the display.
It is possible to reset the timer, or adjust how often it appears, or disable it completely. Exactly how to do that depends on the make and model of your thermostat. Often, it is simply a case of holding two buttons at the same time for a few seconds.
As to why the furnace doesn't come on, there can be many reasons. The problem likely is not the "filter" flashing on the display of your thermostat. Try resetting the breakers that service the furnace unit itself. Make sure that the thermostat is set to "heat" and the setting is turned up. If the thermostat uses batteries (most do these days), replace them.
If this doesn't work, the following information will be helpful to get the furnace running again:
Brand
Model number
Age of furnace
Location in home
Brand and model of thermostat
Feb 28, 2011 | Heating & Cooling
I have a RUUD thermostat and the scrolling message says" change humidifier pad" All I can find is how to get rid of this message. I need to know if I need to change the pad and HOW to do it.
Please follow as per the link pasted here. And after replacing pad reset your thermostat.
http://www.youtube.com/watch?v=RfC_GwvmeVI
Thanks and hope it's helpful.
Jan 07, 2011 | Heating & Cooling
Showing error message sc541
this is an error for the fuser the thermistors have not registered the temps properly check the fuser and if you know how to take it apart clean the thermistors.. you could try an sc reset using the following proceedure...Yellow clear button then 107 then hold down the stop button..wait for the screen to change to show copier sp turn off the machine and wait 5 secs then turn off. If this doesnt reset do the same proceedure on the copier sp enter this then look for mode 5. enter this mode and look for 810 sc reset and set this then turn off wait and turn back on....if this error occurs regularly the thermistors will have to be changed.. hope this helps..A
Jun 28, 2010 | Lanier Office Equipment & Supplies
When i changed oil i forgot to follow the corect proceedures,so now i reading in dashboard of my car . change oil soon . later i follow the proceedures in cataluge , but same sentence appear pls. advise
this light is triggered only by miles. you will probably need to go to the dealer to reset this light. in the meantime try this: 1. Turn the key to the "ACC" position which is the notch that allows power but doesn't turn the engine.
2. The display will read change engine oil soon - hit the display button(i) and the display will read 0% oil life.
3. Hit reset button (the check mark button) for 5 seconds and the display will change to 100 % oil life.
4. It may not work the 1st,2nd,3rd .... attempt , but will work eventually.
Nov 09, 2009 | 2007 Suzuki XL-7
White-Rodgers 1F58-58 to Hunter 44660
This is the corrcet wiring:
G - G fan relay
R - RC1, RC put a jumper RH ( to supply power to the cool and heat)
L - no wire connected (malfunction indicator) tape- off that wire
E - Emergency heat relay
B - W/B ( reversing valve in your heat pump energized during heat )
W2 - Auxilliary heat
Y - Y1 ( compressor contact)
O- Y/O ( reversing valve is energized during cool)
make sure that the system selector is on heat pump position.
Apr 30, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
869 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
