Question about Vacuums
Cannot locate where to plug adaptor in. Sharper Image LumiNight Weather Station EW400 Instructions do not show or explain. Unit comes with adaptor which is mentioned in manual, but cannot locate a plug in on actual unit or sensor.
Hello--to plug in the power you'd need to open the base battery compartment
Posted on Oct 21, 2010
I have an Equity Weather Station model 31215B and i was wondering if the outside wireless thermometer is waterproof .
The wireless unit that transmits to the indoor unit is weather resistant, but not immersible. Even so, try to shield the transmitter from the sun and rain, if possible. When positioning the transmitter, keep in mind that direct sunlight may cause false readings and mounting it on heat-retaining materials (like brick) will show a higher temperature, even after sunset. Avoid mounting it anywhere near things that give off heat (air conditioner units, dark exterior walls, etc.).
LaCrosse has not yet uploaded the manual for this, but you may check later at:
equitybylacrosse.com/31215
Good luck from Detroit, MI.
Apr 29, 2011 | Vacuums
How to set location on IT Works KW9007B weather station
its easy press & hold mode key after flashing time ress mode key again and again till reach london city which is default then press + key set your city and press mode again
Apr 19, 2011 | Vacuums
My dyson dc18 loosing suction , took apart and didnt find any obstructions
Hi its Darran at Dyson.
A loss of performance is normally attributed to a blockage or a dirty filter. Please ensure you follow the full blockage procedure outlined in your user guide or in the Support sectino on our website at www.dyson.com.
You will also find information here on checking the cleaner head to ensure the brush bar is turning and instructions on how to wash the pre filter.
I hope that this information is useful to you and should you need any further help or advice, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Apr 20, 2010 | Sharper Image Dyson Slim DC18 All Floors...
The brushes are turning but there is not suction
how old is the unit? Check the filters for clogs. if you dont find a clog in the hose, cyclone, or filters then its most likely the valve in the neck of the vacuum. There is a small clip that switches this valve from attachments to nozzle when the handle release is pressed. the clip always breaks off leaving the valve stuck in one position. unfortunately dyson requires you to replace the whole cradle assembly
Apr 08, 2010 | Sharper Image Dyson Slim DC18 All Floors...
I own a Sharper Image eVac. It came without a manual. I know how to use the eVac, but I want a manual. Do you have any suggestions? The Sharper Image went out of buisness long ago, so I can't get a manual...
I just got a eVac from craigslist today 12-22-09. Fairly new only been run a handfull of times maybe. This came with a manual but theres not much to it. (15 pages) It is supposed to run about 45 min to a charge and its good to let the battery run all the way down before recharging.
I got a half hour runtime after a couple shorter runs that didnt hold charge very long or didnt run becuse there was a brush sensor error.
I believe these types of batteries are best stored for long periods with some charge left on them, otherwise run it down all the way before charging. Manual says battery temp is a factor in how long it takes to charge, im guessing hotter = longer.
Filter is cleanable with water. No detergent. Fan can be air dusted clean too.
These are my findings after 1 day.
This one didnt want to go on carpet very long before stopping with a "brush error". The 5 small screws that hold the black plate with the red brush sensor window that is directly above the brush comes out easily and exposes the brush sensor in the middle which is quite fragile but can be air dusted clean.
A magnet is good to have on hand, the screws are tiny. With the plate off, I also gently aligned one sensor to be slightly more parallel to the other. This also helped reduce the brush error.
Note which side comes out first because it will want to go back in the same way it comes out. If forced in, this is where you can potentially bend the sensors and undo your careful adjustment and cleaning of them, This is the most critical step so take it slow and have plenty of light to see that no sensor gets pushed askew. Its like Operation The Wacky Doctor Game ...in reverse, dont touch the sides of the window to the sensor...bzzzt!
Dec 13, 2009 | Sharper Image Vacuums
Steam and spray
the heater may be clogged. You will have to take it aprt, pull the hoses off, using somothing small, clean out the prots that the hoses hook to. After that, blow thru it if you can to see if air comes out. Then after it is put back together, put a mix of vinegar and water in and let it run thru until it works good again. Calicum and such plug up the works and just need to be cleaned out.
Feb 13, 2008 | Sharper Image Turbo SM420 Handheld Steam...
Vacuums Logo
81 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
