Question about Systat SigmaPlot 9.0 (000053608314) for PC
I have sigmaplot7, which has been working fine up until the last week. When I open it, click yes to allow spw.exe to alter my hard drive, the program won't open. When trying to open a file created in sigmaplot, it gives the error that 'there was a problem sending the command to the program'. I don't know what has changed since I last used this program. Help!? :) I'm using Windows7 if that is useful. Thanks!
Disable trackpad on sony viao
Right-click the "Start" button and open Windows Explorer.
Open the following folder on the hard drive: C:\Program Files\Sony\Setting Utility Series.
Click on the file named "VCCPointingDevice.exe." The VCC Pointing Device tool opens.
Uncheck the checkbox in front of the "Enable" option and click "OK." The trackpad is disabled.
hope this helps
Aug 02, 2012 | ASUS A6U Notebook
Google chrome appears when I open internet explorer not sure if i started to install but it states to download don't want it can't fine it in the control panel to unistall HELP
Chances are you have accidentally chose Google chrome as your default web browser. To correct this problem you need to run the actual internet explorer. you can find the program on your hard drive. it should be here:
C:\Program Files\Internet Explorer\iexplore.exe
when Internet Explorer (IE) opens up at the top it should see something similar to this:
Click yes.
If you don't see this message then press the alt button and move the mouse cursor to Tools then in the drop down menu select Internet options
go to the programs tab and click make default.
Then afterwards go to the control panel on the start menu and click it.
Choose add/remove programs or uninstall a program depending on what version of windows you have:
locate Google chrome and uninstall it
hope this helps
Apr 21, 2011 | Computers & Internet
Kodak printer not detected
Check in your Control Panel (Printer & Faxes) if the printer is OFFLINE. Via wi-fi network, obtain the IP Address both of Printer & your computer.
Aug 06, 2009 | Kodak ESP 5 Printer
When I turn my computer on, I get a runtime error.
Clean Boot with Only MoSearch loadTOCNode(2, 'resolution'); The Mosearch.exe (Microsoft Office Search Service) and Mosdmn.exe (Microsoft Office 10 Search Filter Daemon) Startup items may be conflicting with some other program (or programs) running in the background. Therefore, clean boot your computer with only MoSearch selected on the Startup menu to determine whether this program is the source of the conflict. To do this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig.exe, and then click OK.
  3. On the General tab, click Selective startup.
  4. On the Startup tab, click to clear all check boxes except for MoSearch.
    NOTE: In Microsoft Windows Millennium Edition (Me), leave the *StateMgr check box selected as well.
  5. Click OK, and then click Yes when you are prompted to restart the computer.
  6. If the error message can be reproduced, repeat the preceding steps. In step 3, also click to clear the Process System.ini file and Process Win.ini file check boxes.
If the error message cannot be reproduced, this indicates that MoSearch is conflicting with some other program or programs running in the background. Follow these steps to locate the conflicting program:
  3. On the Startup tab, click to select one of the check boxes.
  4. Click OK, and then click Yes when you are prompted to restart the computer.
  5. If the preceding steps reproduce the error message, the last item added to the Startup menu is causing the conflict. If the error message is not reproduced, repeat these steps until all Startup menu check boxes are selected.
  6. If all the Startup menu check boxes are selected and the error message is still not reproduced, start Msconfig again, and then click to select the Process System.ini file and Process Win.ini file check boxes.
If this doesn't fix it, let me know and I'll post another, more advanced repair.
Good luck, and please let me know how you do.
~ Spoem
Mar 24, 2009 | HP Computers & Internet
My problem is with MS Photo Editor bundled with Office: I can no no longer run it in a ''normal'' sized window. When I use it to open a JPEG, it starts out minimized, and R-clicking on the taskbar icon and...
Try this:
Find the MS photo program on your hard drive (I believe, but am not sure, it is located here: C:\Program Files\Microsoft\Photo Editor.Exe Create a shortcut (right click on Photo Editor.exe and choose create shortcut) to the program. Then, after the shortcut is created, RIGHT click on the shortcut and click on properties. In the properties windows that pops up, find "run probram MAXIMIXED and make sure that is checked." then, click on OK a couple of times until you can see the "shortcut to photo editor.exe" shortcut. Double-click on that shortcut, which should start photo editor maximized.
Woo Hoo.
Now close photo editor.
Hopefully from this point on every time you open photo editor it will open maximized because you have just tweaked the registry to do so...
Take care,
Rob
Mar 05, 2009 | Microsoft Computers & Internet
Not made a back up, LaCie Hard drive, USB 2.0
To correct and solve this error, follow this steps:
1. Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
2. Stop wscript.exe process if available by highlighting the process name and clicking End Process.
3. Then terminate explorer.exe process.
4. In Task Manager, click on File -> New Task (Run…).
5. Type “cmd” (without quotes) into the Open text box and click OK.
6. Type the following command one by one followed by hitting Enter key:
del c:\autorun.* /f /s /q /a
del d:\autorun.* /f /s /q /a
del e:\autorun.* /f /s /q /a
c, d, e each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
7. In Task Manager, click on File -> New Task (Run…).
8. Type “regedit” (without quotes) into the Open text box and click OK.
9. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
10. Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed):
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”
If the value is incorrent, modify it to the valid value data.
Dec 01, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
This program cannot be run under win32 mode.
Sep 01, 2008 | Microsoft Windows XP Professional for PC
My disk is showing not proper win32 applicaton
you plz enter the drive name of your hard drive same as above.
May 19, 2008 | PQI Intelligent Stick (267027) Hard Drive
Adobe Photo Deluxe 2.0
Go into the PhotoDeluxe2.0 CD ROM file list, right click on setup.exe and then go to the compatability tab. Select Win 98/ME. Hit OK. Then double-click on setup.exe. Program should install on Vista. Then find setup.exe on your hard drive, and set the compatability to Windows 98/ME. Program runs, but says something about not being able to load 16-bit driver. Just cancel out of that popup window. Program works fine...for me...so far.
Feb 02, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
262 people viewed this question
Top Systat Computers & Internet Experts
David Payne
David Payne
Are you a Systat Computer and Internet Expert? Answer questions, earn points and help others
