Question about Haier Dishwashers
I turn it on, press normal wash it goes to pot scrubber and beeps
  • 10,865 Answers
Hello. Do this:
1) Shut off the dishwasher and wait few seconds.
2) Turn on the power again by pressing power button.
Press Start/Pause button. After few seconds drain pump will come on
for short period of time twice. You will hear some type drain pump
noise in the dishwasher. Observe if the drain hose is pumping water out
in to the sink.
3) Immediately turn off the dishwasher after the second drain.
4) If there is still water left in the dishwasher, repeat first three steps again
until the water is removed completely.
Posted on Oct 03, 2010
Visitors from England - owners away - but dishwasher making its presence felt by constantly blipping. Both normal wash - that NORMALLY works well and now pots and pan light up and every few seconds
switch it off at the wall switch while it is beeping for a minute or two this should reset the computer , check the manual to see what the beeps mean,
May 06, 2017 | Cars & Trucks
Why does the water taste funny after two . Months use
Usually taste change is created by a build-up of something inside the kettle or pot. Try the Baking Soda cleaning method:
  • Pour one cup of baking soda into the kettle.
  • Add water to fill
  • Heat the water and baking soda to boiling
  • Unplug the kettle and allow it to set for at least 10 minutes.
  • With a scrub brush or other scrubber, gently scrub the inside of the kettlepot. Be careful not to burn yourself.
  • Once it's all clean, wash with soap and water normally and rinse really well
That will usually get out any old residue that's affecting the taste
Mar 13, 2015 | Kitchen Appliances - Others
My GE Quiet Power 1 is constantly beeping when you press Normal wash, and then just flashing when you press Start/Reset.
Try cutting power to it at breaker box and see if electronics will reset. If not, sounds like a control board problem
Nov 11, 2017 | GE Dishwashers
The soap despenser doesnt pop open during a wash cycle the spring on the lid is ok and the latch spring seams ok we have tried running the hot water in the sink first so that water in the dishwasher is hot...
Sorry to read about your problem, I hope this helps you out.
It will not open on a regular cycle,or normal wash, it will only open on heavy or pot scrubber..
if you are using the heavy setting, and its not working, you have a latch relay problem.
i suggest you contact a service company
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Dishwashers
I have dried on grease stains on the bottom of my pots and also there is a whitish colored film that remains after the pots are washed and dried. I need to know how to clean them.
Spray Oven Cleaner all over stains, SEAL inside plastic garbage bag, leave bag for 2 days, wash pans with scrubber pad, stains should be soft and come off with a little rubbing.
Nov 20, 2010 | Microwave Ovens
My GU2475XTVY0 built-in dishwasher has the "Normal" light flushing since yesterday morning. We pressed "Cancel" button, other buttons, and finally turned the power off and on, but it didn't do anything. Do...
Hello- The touch control pad is failing and must be replaced. If unit is under warranty, get it serviced. This control is about 125$. Let me know if this info helps. Thanks-Ed
Mar 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
The door on our GE Pot Scrubber dishwasher - just
You will have to pull the dishwasher out after disconnecting the water pipe and power.
Simply make a new loop on the broken spring or buy new ones from an appliance dealer and reconnect the spring.
Nov 08, 2009 | Dryers
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Dishwashers Logo
178 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
