Question about Grohe Satin Nickel Soap Dispenser...
Can a brushed nickel soap dish cause green spots to form on white soap
  • 490 Answers
If the finish is scratched and it is brass underneath, yes. Otherwise, no.
Posted on Oct 11, 2010
I am looking for a Greewich (Delta) satin nickel wall mount soap dish and can no longer find any vendor who sells them.
I've found several different styles & manufactures of satin nickel bath hardware at Home Depot and Lowes. Soap dishes,towel rods,toilet paper holders and even matching toilet flush handles.
Jun 22, 2011 | Liberty Hardware Bath Unlimited Greenwich...
Where can i buy a replacement soap tray for the Baldwin Edgewater Wall mount soap dish?
Your product is available here:
http://www.baldwinbrasshardware.com/images_collection/baldwin_bath_edgewater.htm\
The site makes no mention of making available replacement parts. Suggest you contact the company directly to see if they would provide a replacement dish without the complete hardware package.
Contact Information:
http://www.baldwinbrasshardware.com/contact.htm
Jan 22, 2011 | Baldwin Edgewater Soap Dish in Satin...
My ge triton xl dishwasher isn't getting are dishes clean. There is a white film on the glasses and I find dark spots on my plates. There is always dish soap left behind in the dish soap container. It was...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishes still dirty and have white spots all over also
Jul 14, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
White film on dishes every time i run dishwasher
the problem is definately hard water that causes these spots. go to www.dishwasherfilter.com. they make an affordable filter(70 bucks) that fits under the sink and removes the hard minerals before they enter the dishwasher leaving your dishes crystal clean every time. it will work guaranteed or your money back.
Jul 14, 2009 | Dishwashers
Leaving gray white streaks and spots on dishes
Check the following to address this issue--
1. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
2. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
3. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
4. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Jun 01, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Installing a resin shower soap dish,
liquid nails will do the job but you can also use clear silicone provided both surfaces are dry.
Feb 02, 2009 | Daltile Bathroom Accessories Resin Soap...
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishes have soap residue despite using rinse aid. Machine is quite abrasive on coffee mugs etc. Unit is Fisher & Paykel DD605SS
use less soap.....excess soap in the rinse cycle will not allow the dishes to rinse properly causing white etching on the glasses and the dishes will have that gritty feeling
Aug 02, 2008 | Dishwashers
Grohe Satin Nickel Soap Dispenser... Logo
109 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
