Question about LG DLE2101 Electric Dryer
Dryer making a humming noise, but drying fine
  • LG Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Posted on Oct 03, 2010
SOURCE: dryer makes alot of noise when drying clothes.
First you will have to locate the two screws inside the dryer. Open the door and look up inside the trim around the opening of the dryer. Take them out then the top of the dryer will come right out. Look at the very from of the dryer. There should be 4 small "slides" attached to a trim piece. If there are any missing that is probably your problem. I just went through this problem. The pieces each are no longer than an 2" each but cost almost 8.00 a piece. They are easy to replace though. You might also have to replace the whole trim piece as I did because it was completely worn out. Very easy to replace.
Posted on Jan 13, 2009
MNTECH
  • 1543 Answers
SOURCE: Gas Dryer LDG7304AAE making horribly loud noise while drying
Solution for the Maytag model is most likely to replace the blower wheel. Remove the two screws on the front panel (just a couple inches off the floor) and swing the front panel up to allow you to unhook the top side of the panel from the clips at the very top of the front panel. You do not have to remove the wires, just set the front panel to the side. Blower wheel is at the lower left. The old wheel most likely no longer has a D shaped hole to match the motor shaft, and spins freely. Remove cover. Replace the wheel part number Y303836 for a LDG7304AAE which is held on the shaft with a spring type clamp. Reassemble. Not really very hard to do. On a difficulty scale or 1 - 10, I'd rate it a 3.
Posted on Dec 06, 2008
  • 686 Answers
SOURCE: Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Posted on Mar 04, 2009
  • 7 Answers
SOURCE: whirlpool gas dryer #lgr 4634 jq0 not drying and rattling noise
is the dryer tumbling
Posted on Jun 12, 2009
pumpkinman
  • 1144 Answers
SOURCE: Ge Dryer making loud rumbling noise
drum bearings are going up
Posted on Jun 19, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Kenmore 80 series dryer makes loud humming noise when it is drying clothes think it may be a belt that needs to be replaced
More likely is that your motor is going bad...that will make a very loud hum when it starts to go...
DryerRepair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 07, 2010 | Kenmore 65924 Electric Dryer
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
Takes 2-3 hrs to dry a load. Put new dryer hose on. Vent not clogged. Lint filter cleaned each load.
Dryer turn on makes a humming noise intermitantly and won't dry at all have changed coils. It's not the fuse or vent. Help??
Nov 24, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer won't spin
hey first make sure the timer knob is set on drying cycle and not off ( know it might sound stupid but people forget sometimes) and if its making that noise the humming it means you need a new motor 100% sure its not easy to do if you have never done it before
Jun 07, 2009 | Frigidaire Dryers
Dryer vibrating alot and making alot of noise.
check the felt around the inside of the door to see if it needs to be replaced
Apr 23, 2009 | Dryers
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore dryer help?
Sounds like motor is stalled. Remove the lint filter, look inside down toward the bottom left corner at the blower wheel. Something may be jammed in the blower wheel. If difficult to see, TURN OFF POWER TO MACHINE, remove bottom access panel. 2 to 3 screws on bottom of panel. Remove lint housing (3 to 4 screws) and inspect blower wheel for debris.
May 27, 2008 | Kenmore Elite HE4 Electric Dryer
Frigidaire Dryer hums wont turn on
motor-overheated. you might make sure the vent is clean.
Jan 05, 2008 | Dryers
LG DLE2101 Electric Dryer Logo
4,424 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
