Question about Cycling
My Blackburn Neuro 6.0 stopped working - the display unit didn't seem to be linking with the transmitter/sensor. I presumed it was the battery, but it hasn't worked since replacing batteries in both the transmitter and the display unit
    Genius:
  • 1,788 Answers
Sounds like, the magnet on the wheel and the sensor are missing each other, try adjusting the way it passes each as you rotate your wheel. Also, you may have to reprogram after new batteries.
Posted on Oct 03, 2010
Outdoor Temperature Transmitter not working
Sometimes, you have to remove all the batteries in the transmitter and receiver and wait a few minutes before the next step.
Then you replace transmitter batteries first and within 30 seconds, get the batteries installed in the receiver. This allows the receiver to link up with your transmitter. Both units need to be reset this way. You'll see the temperature and any other information the transmitter provides come up in a few minutes. This works with my La Crosse weather station. Using the reset buttons without removing power will not work. My nieghbour has a weather station from another manufacturer and this is also the only way that his will link up.
Oct 03, 2016 | Radio Communications
Hi, I'm looking for a manual for my Blackburn Neuro 5 cyclometer? There used to be an online source but it's gone, not sure what to do?
email the source to put it back up or send you a copy. If the source is gone try the manufacturer's website. If that's gone try typeing "Blackburn Neuro 5 cyclometer manual" in your search engine. If that doesn't work try a different search engine. there's a bounch out there and they're all different.
Oct 05, 2011 | Blackburn Neuro 5.0 Bike Computer
Sigma wireless bicycle computer. Model BC 1606L. Wireless cadence monitor has abruptly stopped working. All other functions of this unit working perfectly. Transmitting unit and receiver have new...
Did you throw the magnet on the crankarm? If not check the alignment of the transmitter and the magnet - sometimes they need to be quite close. Sometimes they just fail. I have seen instances where cadence worked and speed didn't and vice versa - so the unit is transmitting perfectly, but one of the sensors has gone bad.
Jun 12, 2011 | Sigma Sport BC1606L Dts Wireless Bike...
Hi, My Sigma BC 1009 STS does not seem to pair with the transmitter. Once it is mounted in its bracket the MPH flashes but will not stop flashing and will not display any riding information at all....
If the computer is new return it. If not and you have tried a fresh battery on the sending unit and mounting the sending unit as high as possible on the fork, there's really nothing else to try. Check warranty.
Oct 01, 2017 | Sigma Sport BC 1009 STS Wireless Computer
Unit is measuring cadence and heart rate, but is not measuring speed, distance or ride time.
Check to make sure your speed/ distance sensor is in alignment with your wheel magnet. If it is then check the battery in the sensor.
Speed and distance are on a different sensor than the cadence.
Apr 12, 2011 | Blackburn Neuro 5.0 Bike Computer
Re: Hahnel Giga T Pro Wireless Remote Control Hi,
I have exactly the same problem. This product seems faulty or something? My transmitter does not go on and I also can't work out where the batteries go besides if I had to open the thing up and check whats inside (which i do not want to do). The strange thing is that when I plug the transmitter directly into the camera it works as a (wired) remote. Weird. I think I should just have paid the extra money and gone with the original Canon intevelometer instead of this two-bit massed produced piece of shyte. Let me know if you figure out how to operate this frustratingly **** product.
Aug 12, 2010 | Cameras
Blackburn atom 4.0 does not read speed
The magnet has to interrupt the pickup and the transmitter communicates it to the computer, so settings are irrelevant for basic function.
Take the computer off its mount and hold it closer to the transmitter to see if that helps.Then take the magnet off the wheel and wave it by the pcikup to see if that helps.
If neither works, consider that weak batteries in either unit can cause it to fail. Some units also have a minimum and maximum distance within which they'll work.
Jul 07, 2010 | Blackburn 4.0 Bike Computer
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Cycling Logo
162 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
