Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Engine bogging down and starting to smoke - Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
I have the same problem, let me know if you find the answer please! green_lightening@yahoo.com
Posted on Nov 03, 2010
Honda gx620 on golf cart occasionally bogs down & blows enormous cloud of white smoke from exhaust.gas getting in oil also.runs great until this happens
What ussually causes white smoke to come out the exhaust is oil being sucked up in carb. Typical causes are too much oil in crank case or PVC valve. Or really bad piston rings
Feb 26, 2014 | V-Twin Horizontal OHV Engine with Electric...
70 hp johnson outboard,was running fine,then started to blow black smoke from egsaust,lost of it ,then bogged way down
Well, the black smoke is most likely from too much fuel, perhaps a stuck open float valve in a carb. Fix right away, or risk engine damage. Carb surgery is next on your list.
Apr 07, 2011 | RTO Oar Sockets
Started the truck normally and engine bogged down when put into drive and lots of smoke came from exhaust and driver side engine... the smoke came from driver side of engine block under the air filter. Did...
sounds like you just blow out the head gasket,,, thats why you had so much smoke from the exhaust if you wip off the air filter and try to start up you may see puffs of smoke from under the cylinder head,,, dont drive it even if you could,,,untill you sort this out
Nov 15, 2009 | 2005 Ford F 250 Super Duty
Engine bogs big puffs of white smoke from front
the engine will bog because the cutting blades are either cutting to much grass or the blades are touching the ground making it hard to keep rpm's then it will smoke a bit
Jun 05, 2009 | Garden
My scooter is blowing alot of white smoke and bogging down.
replace the spark plug 2cycle engines are hard on plugs also sounds like it needs a carb cleaning black smoke means carb is fooding
Apr 01, 2009 | 2005 TN'G Verona 150
Engine shakes
have the head gasket checked
Feb 26, 2009 | 2002 Pontiac Grand Am
Starter kick back
If this is a gas engine, check the ignition coil or plug wires. A simple test...
Start the truck at night, then look under the hood while it's running. Don't use a flashlight or your headlights; it should be dark !
If you see sparks anywhere around the engine, you've found the problem. Now you can turn on a light to see where they're coming from - probably from a cracked ignition coil.
Good luck !
Marco
Feb 05, 2009 | 1999 GMC Yukon Denali
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
144 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
