Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
I keep seeing a puddle of water at the bottom of my GE Profile refrigerator. I traced the water line, and it is not coming out of that. I cannot locate any drain pan. However, I can see a 14 x 16 sheet of ice on the bottom of the freezer compartment. It seems that something is leaking in there, going to the bottom, freezing, then melting and leaking out to the floor. Any ideas?
    Sergeant:
    Champion:
  • 351 Answers
The drain is stopped it is just under the evaporator a hole in the center pull out draw you will see it. blow it out .may have to chip some ice away or use hair dryer to melt
Posted on Oct 03, 2010
Testimonial: "perfect solution!"
  • texasliz Oct 03, 2010
    Thanks - that fixed it!
Have a 10 year old GE profile side by side refrigerator that has a puddle (2-3oz) of water about once or twice per week comming from back bottom. I have checked the drain in the freezer section about 1.5'...
hi that the only drain going to the pan douse it have an ice maker if so check the water line going up the back to ice maker check around water valve may have a small hole or a hole in pan jim
Oct 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
GE Profile Refrigerator with large puddles of water on floor.
First, your most pressing issue: the water on the floor.
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from coming out the freezer door and leaking onto your floor.
Now, for issue #2, your water dispenser: If you take the front grill off, you will see a plastic tube going through the hinge. There is a coupler, usually a insta-push type just before that. If you push on the collar of the fitting toward the center of the fitting while pulling (not real hard) on the tubing, the tube will come off. Now, try the water dispenser to see of any water comes out the disconnected tube. If yes, comment back to me to see how to fix this, if no water comes out, you most likely have a bad water valve. Reconnect the water line by just pushing it back into the fitting. Disconnect the outlet side of the water line at the water valve and try the dispenser again. No water out the valve almost always will be a bad valve. (there are rare exceptions) Water out valve now when dispenser is pressed equals a frozen water tank or water filter in the fresh foods compartment. Issue #3, your uncovered foods: All the cooling for a refrigerator takes place in the freezer compartment, and some of the cold air is circulated into the fresh foods compartment to cool it. As the air is circulated throughout the entire refrig / freezer, air picks up and transfers odors to uncovered items, including ice. Cover foods and use an open box of baking soda to help absorb odors. Issue #4. (was there a #4?) Oh yes,..... why are you dealing with this? Tell the landlord to have a service company come and check it out. You don't pay the service company, you pay the rent. Landlord is responsible for the repairs.
May 17, 2009 | GE Profile Performance 25.2 cu. ft....
GE Profile TFX27PF/TFT27PF Refridgerator
There is a line from the defroster catch pan, up under the freezer, to an evaporation pan, down under the bottom. If it becomes clogged with dirt, bugs, whatever, the catch pan will overflow, and leave a puddle on the floor. Find it and unclog it.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile side by side no water
trace the water lines, from the sink, to the filter and to the solenoids going to the tank and ice maker. you may need to purge the air inside the water lines.
tnx 4 using fixya,
drcool
Oct 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Side by Side (Not Stainless)
Remove the panel in back of the freezer compartment and clean your defrost drain. It is plugged and overflowing when it goes into defrost. You will see it when you remove the panel. It is probably frozen over so take the ice out of it then run a flexable wire down into the line (nothing to hard or you may pierce or pop the line off) to clean out the drain hose also. Then pour some water into the drain trough (about a cup) making sure it flows freely out. Then remove the front grill (sometimes called a kick panel) at the bottom front of the unit and pull your defrost pan out and check if it has water in it. That will solve your problem.
Dec 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
308 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
